Page 4 of 5 FirstFirst 12345 LastLast
Results 31 to 40 of 42
Thread: Having a little trouble with output.......
  1. #31
    Sep 2007
    Dawson, IL
    Green rectangle - it is a V4
    If anyone gives me a rev - I give them the Bird
  2. #32
    Jun 2008
    Georgia, USA
    Does case matter when defining the brain instance? I noticed that it is different in the output and input sections:
    - <!-- Begin Digital Output Instances
    - <iochannel id="SW Stereo/Computer" port="0" brain="computa brain" type="digital_output">
    <defaults defaultstate="off" />
    </iochannel>
    - <!-- End Digital Output Instances
    - <!-- Begin Analogue Input Instances
    - <iochannel id="Steering Wheel Control" port="0" brain="CompuTA Brain" type="analogue_input">
    <options history="15" auto_average="false" />
    </iochannel>
    - <!-- End Analogue Input Instances
    Thanks,
    Dan
  3. #33
    Fusion Brain Creator
    Mar 2005
    Rick99,
    can you try this to narrow down if it's hardware or software?
    http://www.mp3car.com/vbulletin/fb-s...ion-brain.html
  4. #34
    Sep 2007
    Dawson, IL
    Ran MDX in debug, debug did not appear to do anything(looked a little to see if a file was created but did not find any - was in parking lot before work) and MDX turned on the output as soon as it started as it did before.
    FB Demo worked(had downloaded before just never got to install/run it) - turned output on and off - yea!! , guess it is time to play with/learn some VB.............. thx goes out to mx270a
  5. #35
    Mar 2005
    it's an MDX problem, then. Hopefully Nick will sort it out.
  6. #36
    Mar 2006
    Colorado, but Canadian!
    Not debug mode, virtual brain. See what is going on there.
    1.9in x 2.9in -- 47mm x 73mm
  7. #37
    Sep 2007
    Dawson, IL
    Got it up with virtual brain, only thing I noticed was that the duty cycle was 100% for the output - button turned it on and off(in the display) as I would expect
    With the config set with the virtual brain it still turned on the output on the brain itself when it started and left it on until power was removed from the brain(even when the virtual display showed it as off), should it do this(ie still run the brain when it is in virtual mode)??
    Screens posted below
  8. #38
    Sep 2007
    Dawson, IL
    Off and on screens, brain output 0 is on as soon as mdx is started
  9. #39
    Mar 2005
    We sorted this out, there was a miscommunication between Nick and I on the protocol used to talk to the Brain.
    We'll release either a firmware or software update shortly.
  10. #40
    Sep 2007
    Dawson, IL
    Thanks guys - look forward to it was driving me crazy wondering if I had messed something up(it is a short drive though )
  1. Replies: 7
    Last Post: 01-03-2009, 01:52 PM
  2. using amp output to input?
    By Xprime4 in forum Car Audio
    Last Post: 12-21-2007, 09:26 AM
  3. M-Audio Fast Track Pro: 2.1 Output Possible?
    By speedycheater in forum General Hardware Discussion
    Last Post: 12-10-2007, 01:07 PM
  4. Is all coax/optical spdif output created equal?
    By Choser in forum General Hardware Discussion
    Last Post: 12-19-2004, 02:48 PM
  5. No lcd output
    By JettaMP3 in forum General Hardware Discussion
    Last Post: 03-12-2001, 02:27 PM
