Results 1 to 4 of 4
Thread: Basic Passive Entry System Using FB & eyeR?
    Feb 2006
    Hey Nick & Tim and any other brain users that can chime in on this!
    So I've been researching a car pc for quite some time now and have been researching & reading on embedded elec. etc and FB is definitely what I'm needing for a lot of my desired goals.
    The most important goal and the first I wish to tackle though is a passive entry system.
    Essentially it looks like I'll need an eyeR & FB to do this as the FB needs the computer to operate correct?
    So, the main two questions I have are:
    1. How would I integrate a bluetooth transmitter and receiver with the FB?
    If essentially I'm wanting to have a transmitter in my pocket as the "key" and when I let's say get within 10 ft (which from my understanding bluetooth transmits different voltages from different distances so if 10ft = 3v) then it would trigger an event to unlock the doors. And then consequently if voltage < 3v it would lock the doors.
    2. The second question is doing a certain action based on the length a button is pressed. I'll try and make this as easy to read as possible
    1 Button
    4 Possible Actions
    -Action A
    -Action B
    -Action C
    -Off (Revert to no power and no action)
    If button press < 5000ms Then
    If Action = Off then
    Action A = True
    Else
    If Action = A Then
    Action B = True
    Else
    Action Off = True
    End If
    Else
    If Action = C Then
    Action Off = True
    Else
    Action = C
    End If
    End If
    How could I do this? Or can I do this? The vehicle would there again be off for some of these actions so would eyeR be needed for this?
    Thank all of you in advance for any help/support! I'm so excited about this project and all there is to learn!
    FLAC WuNgUn's Avatar
    Sep 2007
    Maybe Connect2Car MFC is what you need instead?
    Mar 2006
    Colorado, but Canadian!
    Quote Originally Posted by w00tw00t111 View Post
    Correct, the FB as we provide needs a PC to operate. We dont use/develop the eyeR, but from what I can tell it can operate without a PC especially the IR part as far as I know.
    It is not that simple at all. Bluetooth is a digital communication protocol that requires lots of handshakes. For this to work, you will need a seperate programmable microprocessor to handle the bluetooth side. It will need to monitor an open bluetooth receiver, wait for when a module is in range, start the handshake and security exchange, and then wait to receive data such as "unlock". Bluetooth is not simply a distance/voltage at all.
    1 Button
    4 Possible Actions
    -Action A
    -Action B
    -Action C
    Action A = True
    Else
    If Action = A Then
    Action B = True
    Else
    Action Off = True
    End If
    Else
    If Action = C Then
    Action Off = True
    Else
    Action = C
    End If
    End If
    You would need to use a lot of logic blocks in MDX to do that, but that means the computer needs to be on for the logic to work.
    I dont know how the eyeR is programmed, so I dont know if that is possible.
    1.9in x 2.9in -- 47mm x 73mm
    Low Bitrate GadgetBandit's Avatar
    Oct 2008
    As you get near the vehicle, there is no way of preventing the doors from unlocking. That's a breach. Then once your inside, you have to disable the transmitter to lock the doors. I'd stick with the "active" transmitter/receiver to control entry.
    I looked at the wireless and I think one had 4 channels. I'm thinking of using one to fire up the PC from a distance and have a couple inputs for the brain. Justs my thoughts.
    GadgetBandit
  1. Replies: 85
    Last Post: 07-09-2007, 05:44 AM
  2. Security System thoughts
    By techy101 in forum General MP3Car Discussion
    Last Post: 07-28-2005, 04:42 AM
  3. FS: VIA M9000 System
    By fromplanetbob in forum Classified Archive
    Last Post: 06-01-2005, 08:03 PM
  4. looking for keyless entry system
    By yonu in forum Classified Archive
    Last Post: 05-22-2005, 12:00 AM
  5. Really cool alarm system using Basic stamp
    By lstrunk in forum General Hardware Discussion
    Last Post: 06-13-2002, 08:08 PM
