Results 1 to 10 of 14
Thread: does the fusion brain work as a standalone device?
    Dec 2001
    my parents house ;-)
    or does it need to be hooked up to a computer when running?
    Fusion Brain Creator
    Mar 2005
    needs to be connected to a computer.
    or, you can re-write the firmware.
    May 2009
    That's exactly what I'm looking for too (a standalone FB). That would've been awesome. Could the FB creator please comment on this? I guess it would need some kind of a flash memory on board + perhaps a cpu?
    Mar 2006
    Colorado, but Canadian!
    Quote Originally Posted by 64Chevelle View Post
    greenman100 and I are the creators.
    It can be done, but think about this... How many different ways would people want standalone firmware to be written? It is not feasible. You can rewrite your own firmware if you want, but it is going to be a pain in the butt.
    The main chip contains a CPU and memory, nothing additional is needed other than a crapton of firmware programming and in the end it would be so personalized it would be pretty much worthless to anyone but yourself.
    So possible, yes. Feasible for us to do on a large scale, not at this time.
    1.9in x 2.9in -- 47mm x 73mm
    May 2009
    Quote Originally Posted by 2k1Toaster View Post
    If I understand you correctly there is no logic processing in the FB cpu/firmware itself. It relies on a running program on the connected computer to tell it what outputs to open based on values from the inputs. The program on the computer computes the outputs based on logic stored in an xml config file.
    Couldn't the logic configuration be stored in the FB memory and the FB firmware handle processing of the logic?
    Or have I totally misunderstood how the FB works? I haven't been able to find that information in the documentation.
    Jun 2004
    The hardware on the FB CAN do what you are asking, but the software would need to be customized on the chip for all the logic (I'm not sure you'd have enough space/power to make it update-able in real-time or by the PC, I kinda doubt it). It would basically become it's own little computer (it already is, but then it would think as well).
    Like they said, you can have it their way OR you can develop a solution yourself (and the hardware is available if you want to take that challenge). their way is more customizable, but requires a PC. I wouldn't dream of taking orders to customize the logic to CarPC'ers specs. that would be a nightmare
    Mar 2005
    You're correct.
    The problem is converting the logic blocks you see in the configurator to code the FB can use. It can't really be automated - we'd have to write code for every standalone FB, and if someone wanted a change, write new code.
    May 2009
    You may want to check out Arduino
    Variable Bitrate Redian's Avatar
    Apr 2006
    Connecticut, USA
    Quote Originally Posted by digital79 View Post
    arduinos would probably be a better choice in this case seeing how it was made to be a stand alone device.
    the fusion brain was made to be controlled by a PC, and thus.. makes it harder to do the things you want without a pc
    although, you will still need to code quite a bit.
    2004 Impreza WRX CarPC Install
    I am willing to host any legal downloads that may benefit the CarPC community - PM for info
    "When you go 0-60 in 4.5 seconds, you don't need a made up character called fast. Thats what makes a Subaru, a Subaru."
    DG4L
    North of the land of Hey Huns
    Jun 2004
    Westminster, MD
    I've used the arduinos both at work and for personal use, and I have to say they're fairly awesome. You can even get a "shield prototype" which will allow you to add things like the darlington driver arrays that the fusion brain V3 uses for digital outputs right ontop of the board.
    Quote Originally Posted by mitchjs
    stop with the REINSTALLS, what do you think we got some lame-o installer!!!
    RevFE - Super fast, modular frontend. Most powerful skinning engine in existence. Strong enough for an i7 made for a fitpc.
    Just a shame I can't justify a carpc to use it on anymore.
  1. need help on fusion brain 25A Relay wireing
    By wethecom in forum Power Supplies
    Last Post: 09-01-2008, 03:59 PM
  2. Noob has some biginner questions about the Fusion Brain
    By phreaknes in forum Fusion Brain
    Last Post: 04-29-2008, 03:57 AM
  3. Replies: 5
    Last Post: 10-22-2007, 09:40 PM
  4. Fusion Brain Integration
    By michael2 in forum RR Plugins
    Last Post: 08-22-2007, 12:59 AM
  5. Replies: 4
    Last Post: 11-18-2002, 09:59 PM
