Page 2 of 2 FirstFirst 12
Results 11 to 14 of 14
Thread: HVAC help with Fusion Brian
  1. #11
    Mar 2007
    time to re-visit this..
    I don't want fusion brain to take over and maintain the HVAC, that may come later. All I want is it to push the buttons to turn it on, change options (buttons), adjust temperature, turn on/off A/C or just the heater while letting the car itself control the HVAC
    So basically just activate buttons or turn the temp dial through signals to the correct wires. Since the physical buttons aren't reachable when my CarPC screen is up.
    Is this possible and simple to setup without programming? Can the existing software do it just requires some configuration?
    thanks
  2. #12
    Mar 2006
    Colorado, but Canadian!
    Quote Originally Posted by jabz View Post
    thanks
    Yup.
    1.9in x 2.9in -- 47mm x 73mm
  3. #13
    May 2007
    Hi
    I have the same heater control and was thinking the same thing.
    In addition to controlling the buttons with the Fusion brain i was thinking of trying to get the display to work on the Car PC as well. I.e the temprature etc..
    I have looked at the software that come with fusion brain. I would like it to be integrated to centrafuse so that i can see the heater reading from there.
    will have to look into it
  4. #14
    Oct 2009
    Hey! Any updates?
  1. Fusion Brain and Auto HVAC. h3rk where are you?
    By Willn in forum Fusion Brain
    Last Post: 04-17-2009, 09:08 AM
  2. Replies: 17
    Last Post: 01-16-2009, 09:48 AM
  3. Replies: 3
    Last Post: 09-23-2008, 09:00 PM
  4. How to add a Fusion Brain instance to your configuration file
    By 2k1Toaster in forum FB Documentation and Tutorials
    Last Post: 06-07-2008, 08:42 AM
