Results 1 to 4 of 4
Thread: Questions about connections...
    Jan 2007
    I'm in the process of finally hooking up my Fusion Brain. I have the v3. I have tried searching the forums and I'm sure its out there somewhere but I can't seem to find them.
    Here is my 2 questions...
    Looking at the v3 board with the USB port facing to the left, which way does the pins for the digital outs go. is it 0 - 11 or 11 - 0?
    2nd question... When connecting the relays to the board, does the positive (red) wire go on the inside pins or the outside?
    Once I have these questions, I can finally get this hooked up without worrying if I have it hooked up right or now.
    Allen
    Mar 2006
    Colorado, but Canadian!
    The relay doesnt matter for polarity since it just drives a coil.
    Ports vs. pins: http://www.fusioncontrolcentre.com/F...rdware_004.php
    1.9in x 2.9in -- 47mm x 73mm
    Jan 2007
    Quote Originally Posted by 2k1Toaster View Post
    ok, so it doesn't matter which way the relay wires go on the board. thats easy enough.
    For my other question, I saw that diagram already about the ports and pins, but doesn't really answer my question. I would like to know which side does port 0 start with or which port starts closes to the USB port.
    Hopefully I explained the question a little better.
    Allen
    Jun 2004
    just plugged in my v3 - The LED for DO-0 is the furthest from the USB connector (DO-11 closest to USB/power connector). As for which pin corresponds to DO-0, you will have to test. Mine didn't match the conversion table listed (0=7, 1=4). Silly Chinese
    A multimeter will tell you all this much faster than waiting 3 days for somebody to respond
  1. Alpine PXA-H701 Questions
    By unixxx in forum Car Audio FAQ
    Last Post: Today, 09:09 AM
  2. INFILL G4 - Australian and New Zealand Questions Answered
    By INFILLG4 in forum General MP3Car Discussion
    Last Post: 04-30-2008, 12:21 AM
  3. Replies: 8
    Last Post: 03-25-2007, 10:20 PM
  4. Replies: 4
    Last Post: 12-29-2006, 01:16 PM
  5. Replies: 3
    Last Post: 08-24-2006, 08:12 PM
