Results 1 to 10 of 10
Thread: Fluid Level Sensor hookup
    Mar 2009
    I bought this nice fluid level sensor that is powered by 12vdc and outputs 0 to 5 vdc. 0 being empty, 5 being full. So my issue is, I have 2 leads(+,-) from the 0 to 5 vdc source and 3 leads(+,-,an) on the analog input of the FB. To connect a voltage source to the analog input, which leads are used and how?
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Moved to FB main forum and the Tutorial and Documentation forum is for?
    Yes you guessed it Tutorials or documentation.
    Mar 2006
    Colorado, but Canadian!
    Then AIN is the analogue input. That is what does the reading.
    Ground is ground.
    so your sensors + output goes to AIN. Your sensors ground output goes to -
    1.9in x 2.9in -- 47mm x 73mm
    Nov 2007
    Quote Originally Posted by jctman View Post
    did the fliud sensor worked for you?
    Low Bitrate GadgetBandit's Avatar
    Oct 2008
    I'm also interested to know how this worked out.
    GadgetBandit
    Jan 2006
    any updates on this?
    Oct 2008
    Guess this didn't work out. Any other ideas on fluid level sensors . . . that I could adapt to a rain barrel.
    My brain has been running the greenhouse for a year. ta da! Including hydroponics. But, I need to manage water levels.
    Thamks,
    GadgetBandit
    Mar 2006
    im sure it did, i dont see why it wouldnt. Probably just not a follow-up type person
    Mar 2009
    Yes, the sensor worked perfect. I will not however work on a metal tank.
    Dec 2009
    ROD Type works in metal tanks
    The Rod Type sensor is same capacitive sensor contained/sealed in PVC rod.. same outputs. This sensor works in metal tanks as it is away from walls.
    Order custom length from website and screw in top (or in side if use bent)
    Works with most liquids (Capacitive)... if question just email them they are good on that.
    ___
    If you need a smaller diameter sensor - make it yourself - plenty of websites. Or better you can make your own contact capacitor ladder sensor and put out a pulse train for easy uP input. But if you can use their sensors, especially given packaging/sealing etc is just so much easier at their pricing (always a trade off)
    __
    And just in case - I AM NOT Affiliated with them... just been needing a waste level sensor and most commercial are outrageous - so worked on my own but given theirs and price/configuration - purchasing theirs. Using a pic micro to take analog and send as digital data stream (LIN or CAN). uP will also serve as default controller for waste level management based on power availability.
    < Unmonitored Responses>
  1. n00bular question about output level
    By kevin1162 in forum Car Audio
    Last Post: 03-04-2009, 08:01 AM
  2. Replies: 2
    Last Post: 07-30-2007, 08:31 PM
  3. Headphone vs line level outputs from computer, etc.
    By timeshifter in forum Car Audio
    Last Post: 12-31-2006, 01:21 PM
  4. high level inputs and low level inputs, what does it mean?
    By TiTUS in forum General Hardware Discussion
    Last Post: 09-28-2003, 10:51 PM
