Page 1 of 5 12345 LastLast
Results 1 to 10 of 47
Thread: FB to control audio switching?
    Jun 2008
    I need to leave my headunit in my car so whenever my PC is not in, I'll still have radio. Now I need to figure out someway to switch between the radio and PC when I do have it in the car. I was thinking I could use my version 3 FB to turn off the radio on a button click to use the audio from the PC. Then on another button click turn off the PCI soundcard (possible?) and turn on the radio. That way they'd never overlap sounds.
    1. Does anyone know if this is possible with the FB (I have the FB, but havent even built the PC yet so I havn't had time to play with it)
    2. I know having audio come out of the radio and into the speakers and soundcard at the same time can damage the soundcard, and vice versa if the soundcard is playing music into the radio. Does anyone know if turning the device off like I described above would prevent the signal coming out of one device from damaging the other device.
    3. If it is possible, and there is no risk of damaging the devices in this way, what happens when the FB and computer are out of the car? How could I turn on the radio if there is nothing controlling the realy that FB controlls to turn the radio on and off?
    This is the only way I've come up with switching the audio. It be a lot simplier I think if I could just have both devices outputs plug into a switcher of some sort then have the FB operate the switcher. But I can't find any sort of switcher...only mixers that mix the signals together.
    North of the land of Hey Huns
    Jun 2004
    Westminster, MD
    It's a bit pricey, but still an awesome solution, and seems tailor made for what you want to do.
    http://www.rush2112.net/mkportal/mod...8f6207ffa0bb22
    Edit: Don't get me wrong, the FB is awesome and you should find a different use for it... but for audio switching that seems a better solution.
    Quote Originally Posted by mitchjs
    stop with the REINSTALLS, what do you think we got some lame-o installer!!!
    RevFE - Super fast, modular frontend. Most powerful skinning engine in existence. Strong enough for an i7 made for a fitpc.
    Just a shame I can't justify a carpc to use it on anymore.
    Jun 2008
    Well this is a little different. So instead of controlling the power to the radio and soundcard, this device would let me control which audio source is given to the amps. I like the idea...however I see a couple hang ups
    1. I would need one of these devices for each channel. I can't have L/R Tweets, Mids, and Bass being processed by the computer then put into a single input on this box. That defeats all the processing. A box per channel becomes very pricey.
    2. When the computer is out of the car, is this device smart enough to know to use the only input it is getting signal from? I wouldn't have the computer there to switch it over to the radio input otherwise.
    Jun 2004
    You need to isolate the 2 inputs - you can't just splice them together & turn one off. You'll eventually damage the output circuit on the PC or Radio (or both). if it's a pioneer h/u, it might not survive initial connection.....
    You haven't given enough information to really give advice - knowing what components you're using would help a lot (sound card, processing, h/u model, speaker setup, etc) It sounds like you want multi-channel from the carPC, but stereo from the radio, not sure how your are planning that to work. You might be able to take the device suggested above & modify it to select channel 1 or channel 2+3+4 if you need 2 + 6 channels. then it depends on how your amps are hooked up (that device wont output 6ch)
    My suggestion would be to use an external processor, then use the FB to switch it's inputs (my RF 360.2 can do that (2ch input, has an external input select + volume), haven't looked at how the signal switches inputs though I'm sure the FB could be adapted to work). You'd run stereo to both inputs, then you can do all your EQ, T/A, x-over in the processor. If you're trying to run 3 way front + sub, that's they only way you'll get sound from your 2ch radio & 6ch computer, if I'm guessing your system correctly. You also tune the 360 via bluetooth, so the CarPC would be useful there
    Jun 2008
    Well the reason I can't give too much information is because I'm trying to keep this as universal as possible so I can move it from one car to the next. Each car will be different so its hard to give details about headunits and amps and such.
    Processing must be controlled by the computer (PCI card, external card, doesnt matter in this senario) because I'm not putting seperate processors in each vehicle. This way, when I remove the computer from one vehicle and put it in the next, the processor will come with it and all I have to do is load the saved settings for that particular vehicle.
    In a vehicle without amps: The speakers plug directly into the headunit. What I need, is the speakers to plug into a switch. The headunit would also be plugged into this switch. So when there is no PC, everything works as normal. When you put the PC in the car you plug the audio outputs into this switch. You could then just choose which source you want to use. You would have to have a way to choose without going back and manually pressing the switch in the trunk of the car though.
    In a vehicle with amps: all the same applies except the output of the switch would be to the amps obviously.
    So here is a solution I'm thinking of. At this website How-To: Make a component video switch They show you how to take a KVM and turn it into a switch with RCA plugs instead of VGA and PS2 plugs. They only attach 3 RCAs, but if I modified it for 4 RCAs I think it might work. If the computer is not in, the KVM will switch to its only input automatically. If the computer is in, then you just switch between the radio and computer via a keyboard keypress which you can handle in code.
    this is going a little off topic because the FB is not involved in any of this. But I think it might work as long as that switch does not tamper with the audio signal or degrade it in anyway.
    Jun 2004
    Westminster, MD
    You can't drive standard car speakers with your computer audio outputs, they're line level (eg unamplified). You're going to need to run them through the headunit, or through an amplifier.
    For the second situation:
    You can't tie your headunits amplified outputs into the input on an amplifier. You're going to blow out the amplifier. If by chance, the amplifier has high impedance inputs, you could use those... but they usually sound horrible and most amps don't have them.
    Jun 2008
    Quote Originally Posted by malcom2073 View Post
    Hmm...Didn't know that...now I need to find a super small basic amp to use is this situation. Here is where I wouldnt want to upgrade the amps and speakers in the vehicle, just use what is already existing. But if there is no amp in the car, and the speaks are getting their signal from an amplified headunit, I'd need a small amp for the PC to use. Can I rip one from an old headunit or is there anyplace to buy small amps like the ones used in headunits?
    My mistake, I didnt clarify on this. When there are amps in the car, I'll be using the RCA outputs of the headunit to go into the switch.
    Jun 2004
    Westminster, MD
    I'm not entirely sure about small amplifiers, I've been looking for one myself really. Another issue you might run into, is getting a switch beefy enough to handle how much power you're going to be putting through it.
    The second situation in that case would work, though I'm not sure about the KVM part. I assume you're thinking of using 6 channel out going to a 6 channel amplifier for your 6 speakers? If so, does the headunit output 6 channels over RCA?
    There's gotta be multi-channel audio signal switchers out there.
    Jun 2004
    I don't think there is anything on the market, or simple to make that can do what you want to do. You might have more luck trying to get the computer & car(s) to read your mind and just do what you want
    Almost all makes & models of cars have different audio setups (I work in the manufacturing of 4 different models) so trying to tie 1 solution into multiple setups is a PITA (trust me on this one) then you add in custom setups and you're at another level of hell.
    You haven't said how far you want to go with processing - is a little eq enough or do you want T/A, x-over etc. if it just eq & stereo - use the Aux input on the car's h/u & run the computer output to that (or a frequency modulator). If you want more (multi-channel, T/A, x-over, etc) you need seperate amps, component & wiring (no stock vehicle).
    If you want this to work with multiple vehicles, I think that's how you're going to have to go (Aux or a tunable frequency modulator (wired/wireless))
    There will probably never be a drop-in, 100% solution for a CarPc, let alone a solution that can handle multiple makes, models etc - there's too much variation within the industry for that. Unless we go back to Any-Color-you-want-as-long-as-its-Black type manufacturing (considering the current socialization of the auto makers, we might all be driving VW Beetles soon, so it might be easy to do )
    Jun 2008
    Quote Originally Posted by Iamthehor View Post
    Yeah, that would be the best..haha.
    Looking at any headunit, you either have wires going straight to the speakers, or you have outputs (usually RCA) that goes to an amp or processor or something. Am I wrong by thinking this? Is there something else I could be missing right there at the headunit?
    I'm just thinking that if I catch the audio at that point, I only have a few different scenarios to think about.
    1. There is no amp/processing/anything in the car so I need to use the speaker wires on the back of the headunit and an amplified signal from the soundcard on the PC. Put both of them into a switch (if its beefy enough...I can do some testing and determine that) and have the output that I want to go directly to the speakers. It doesnt matter how many channels each device inputs into the switch because at the output of the switch I can combine any channels that need combined and send all the signals where I need them.
    2. There is an amp or processor or something connected to the stock headunit via RCAs. In this case, I would intersect the RCAs as soon as they left the headunit and run them into the switch. I would then run the rcas out of the PC into the switch. Again, it doesnt matter how many channels were ran into the switch, I would only use what I needed on the output side.
    3. There is an amp or processor or something connected to the stock headunit via some digital cable....when that day comes...I'll worry about it then. I dont plan on owning a vehicle with that advanced stereo system stock for quite a while..haha.
    crossovers, eq, times shifts or whatnot will all be handled in software...that should not effect what i'm trying to accomplish. Number of channels will be determined by whats already in the car. If its stock 4 speakers...then the output of my switch I will configure for 4 speakers. If there are 3 amps..then the output of my switch will be configured to send highs, mids, and sub signals to their amps.
  1. RoadRunner, Vista and you (Audio thread)
    By mitchjs in forum Road Runner
    Last Post: 05-27-2009, 09:15 AM
  2. Alpine CDA-7949 audio input with volume control
    By STEviltoo in forum General Hardware Discussion
    Last Post: 02-07-2009, 05:17 PM
  3. no audio control with XM plugin
    By DalenA in forum CF Bug Reports
    Last Post: 10-12-2007, 11:26 AM
  4. Audio Control
    By bklynkaos in forum ME Archive
    Last Post: 12-30-2003, 08:14 PM
