Page 2 of 2 FirstFirst 12
Results 11 to 19 of 19
Thread: Fusion Brain v4 help
  1. #11
    Mar 2006
    Colorado, but Canadian!
    Quote Originally Posted by monty9991 View Post
    i have this on my power supply "output: 12v~800mA 9.6VA" , is this good?
    VA is usually volts AC which wouldnt work... But does it say 12VDC ~800mA on it? That should work then as long as its centre pin positive on the barrel.
    What is this wall wart from?
    1.9in x 2.9in -- 47mm x 73mm
  2. #12
    Nov 2007
    this is from my modem. input is 220v-240v AC
  3. #13
    Mar 2005
    Can you take a picture of the label? I'm pretty sure you're feeding the board AC.
  4. #14
    Aug 2007
    Northern VA
    How about verifying with a multi-meter? If you don't have one you will need it sooner or later anyway.
  5. #15
    Nov 2007
  6. #16
    Aug 2007
    Northern VA
    Yeah I'd be wary that it doesnt say DC. The one I am using is from on an old switch and says DC.
    My FB v4 came with a power pigtail - don't recall if I ordered it in addition or if it came with it. If you have one, just add some wire and test with your car battery real quick. You should be able to quickly confirm normal operation using the car battery as the power supply.
  7. #17
    Nov 2007
    Quote Originally Posted by cgalpin View Post
    i too have that wire, i ordered it along with FB. i shall check that in the morning tommorow now as its late night here in india.
  8. #18
    Mar 2006
    I wouldnt trust it, just use another wall wart or something that you are sure of. Doesnt make sense not to and blow up your FB...
  9. #19
    Nov 2007
    Quote Originally Posted by 2k1Toaster View Post
    i wish i also dint trust that power supply earlier.
    i did a test in my car with connection to the battery, and VOILA.. i got it work.
    but one of my relay is not working for some reason. may be manyfacturer's defect.
    thanks all for your help.
  1. *NEW* USB Input/Output Board -- Fusion Brain
    By 2k1Toaster in forum Fusion Brain
    Last Post: 02-22-2010, 03:33 AM
  2. Fusion Brain V4 Digital Inputs
    By malcom2073 in forum Fusion Brain
    Last Post: 02-14-2009, 12:16 PM
  3. Replies: 17
    Last Post: 01-16-2009, 10:48 AM
  4. Replies: 3
    Last Post: 09-23-2008, 10:00 PM
  5. How to add a Fusion Brain instance to your configuration file
    By 2k1Toaster in forum FB Documentation and Tutorials
    Last Post: 06-07-2008, 09:42 AM
