Page 2 of 4 FirstFirst 1234 LastLast
Results 11 to 20 of 32
Thread: Back in the game.. althoooo
  1. #11
    Jul 2005
    ok so ive moved my images across to carpc.. workin a few buttons and ansd stumbling across some issues which i cant afford let happen...
    Ok, so im setting up the buttons as..
    on click trigger "Left Front Fill"
    and on lift trigger "Left Front Fill"
    so in turn your relay is only open the time ur finger is on the button, but this seems to not always catch your click off.. and its getting out of sync with itself.. making the relay stay open.. then click and it closes etc, and it goes on and off.. and doesnt always reflect properly what should be happening...
    now this becomes a big problem because air valves will remain open.. and ultimately my vehicle will hit the ground..
    now im guessing there is other ways of going about this.. maybe other options in the buttons? or setting a variable for each relay.. to 0.. then on click set var. to 1.. but i can still see this interferring with itself and not catching the click off.. i really want to be able to hold the finger on the button and be able to control it that way... if there isnt a reliable way of doing this i guss ill be forced to goto preset heights?
    what are your thoughts?
    EDIT:
    Also ive noticed when i change the settings to hide the outside bar, it just makes it transparent and the edge is actually still showing, this creates a bad edge and is also disorting my images because its pushing the image inward by around 4px a side i think? is there a way to eliminate the border and stretch the main BG image to full screen?
    Ryann,
  2. #12
    Mar 2006
    Colorado, but Canadian!
    Quote Originally Posted by Ryann View Post
    **** 2k, lol i just added all them buttons, saved... closed.. reopened, opened file... bareee.. nothing..
    You did click "save" on that screen right?
    1.9in x 2.9in -- 47mm x 73mm
  3. #13
    Mar 2006
    Set the down click vote to turn on whatever digital output that is on low priority. Then set the up click vote to turn off whatever digital output that is on medium/high priority.
    Ryann,
    The hiding of the bar is all internal microsoft code. I just tell it to not show the border, and the rest is done by them so nothing I can do.
    If it is off by 4px, then maybe design for 4px more/less depending on what you mean and see what happens. You have a screenshot of this?
  4. #14
    Jul 2005
    i dont have a screen of it no 2k.. ill try but its on the carpc with no photo stuff on it.. ill see how i go..
    and yes im certain i saved it, i tested it afterward again i just set the backround.. saved it.. then closed, opened, loaded and still bare bones.. this only happened on my desktop with no brain attached.. or set.. on my carpc it works fine.
    and ill look into this voting.. all im doing is triggering the same digital output for on click and off.. so u mean set the onclick to low.. and off click to high in the button settings..?
  5. #15
    Mar 2006
    Also looking at that image you have with the buttons, you didn't change the global graphics properties. You are just going to have a big edge around it. When you first open the app up on the top bar there is "Graphics Configuration" and you can choose all those details.
  6. #16
    Mar 2006
    And this is saving from the graphics screen NOT the main screen behind it...
    That's part of what I said, but there are lots of options for a Digital Output. Are you using toggle, on, or off for your votes? For something like this use explicit on and off with the different priorities.
  7. #17
    Jul 2005
    yea 2k that was before, its been handled after that..
    can u go into more detail about the vote setup, this all done in the button creation?
  8. #18
    Jul 2005
    Quote Originally Posted by 2k1Toaster View Post
    both 2k, ill do more tests and get back to you, altho i might mention, due to some error anyway i cant open the main program i can only open the configurater.. i was hoping i could config it all and change it over to my car pc, maybe that has to do with it also...
  9. #19
    Jul 2005
    im not using toggle at the moment, im unsure on howto use the different options.. i cant find much info on all of it..
    Ryann,
    EDIT:
    Just testing again on my home pc.. once i added a fake brain.. it worked seamlessly... buttons worked and saved and open.. seemed to only play up because i had no brain added in there at all..
  10. #20
    Mar 2006
    Did you do the full install on both computers? What error does it give you?
  1. modify monitor case w/o back
    By Mike12086 in forum LCD/Display
    Last Post: 12-08-2006, 10:04 AM
  2. I'm back! How have you all been?
    By J187 in forum Road Runner
    Last Post: 12-06-2006, 09:58 AM
  3. Replies: 4
    Last Post: 03-23-2005, 11:33 AM
  4. Replies: 5
    Last Post: 01-03-2005, 09:39 PM
