Page 1 of 4 1234 LastLast
Results 1 to 10 of 32
Thread: Back in the game.. althoooo
    Jul 2005
    LOL, ok guys im glad to say im back, i have finally go my car back from the paint shop and am implementing mysetup now..
    I have my brain hooked up.. mdx all installed.. and am in the process of learning the configurator.. Now this looks promising, altho im lost..!
    i have successfully added my brain.. also successfully added my 8 relays as digital outputs that will be activating my solenoids (air suspension).. in mdx... Now heres were i come unstuck.. ive done some searching but none that helps.. ill point form these out to make it easier..
    * fonts.. add font? how? do i have to add a font to the content folder?
    * adding buttons.. at the moment the actual create button screen is bigger then my lilliput and i cant scroll down to finish it, altho my above problem gets to me first, the font?
    goals..
    currently, just focusing on having 8 buttons.. one for each wheel raise and lower..
    from there id like to create buttons to lift the two front wheels and lower the two fronts.. simutaneously.. same with rear..
    voice controlled would be nice...
    but ultimatley functions to set it to auto ride heights... in con junction with my air pressure senders..
    also was hoping i could set a hidden button *safe mode.. were no matter what was pressed, it wouldnt lower below a certain pressure... or maybe i can just make a separate screen with limitations in the buttons..
    let me know guys, this software seems powerful! i just not sure on harnessing just yet.
    ryann,
    Jul 2005
    Heres 2 pix, one of my ride... and one of my *test setup* haha
    Jun 2004
    Looks like it's going to be a sweet setup. Taco? I can't tell the model from the picture. Love your MoBo mounting solution....
    I haven't used MDX much lately, focusing on VB2k8, but I'll try to answer some questions.
    fonts were weird, i just used the default cause i didn't feel like figuring it out.
    You're gonna need a full-size monitor for dev (at least 15" IMO). The configurator screens aren't resizeable or scrollable. My laptop even has problems (14.4"). You can make the skin fit to the liliput though. Why sit on the floor to program anyway? get comfy & you'll think better
    You could (and should) set hard limits for max & min pressure as variables - you don't want some jackass reaching over & adding air when you are near peak pressure - that can get expensive. 1st thing button logic should do is make sure you are above & below those variables before executing any add or release of pressure.
    I would guess you'll want more than one screen - I think I'd do at least 3 - 1 for Monitoring + kinda a "cruise" mode where you wont make many adjustments, 2 a presets screen, 3 and all out, change whatever you want screen. You might be able to do the Presets & monitoring on one screen - depends on how you use the real estate.
    What front end will you be using? RR is about the only one that can use MDX as a plugin (I haven't researched that much though). You might be better off getting the integration between programs working before you start to make your skin - you might need to move stuff around. I think i would make a separate MDX program that mirrors what I used though, you never know when something will crash, leaving you on the ground - literally.
    Mar 2006
    Colorado, but Canadian!
    Look in here for your font answers: http://www.fusioncontrolcentre.com/T...ual%20b005.pdf
    The display button screen I have changed to be tabbed, that update went out 15-06-09 at 2am MST. Current Configurator version is 1.0.0.275
    MDX can be embedded into any program that supports embedding. I have been told CF has problems with the title bar, but you can hide the bar in an MDX setting rather than relying on the embedding program to do it so that gets rid of that.
    If you have any other questions, let me know.
    1.9in x 2.9in -- 47mm x 73mm
    Mar 2006
    Also I moved this out of Documentation and Tutorials since well... it isn't!
    Jul 2005
    ok few hiccups here... 2k anyway of changing the display page in the configurater. size to 800x480? as thats my screen reso? otherwise i have a weird distortion?
    as im on a pc ith no fusion attached.. a dummy brain attachment would be a brilliant idea i seen mentioned elsewere, so i can program evrything and save, and transfer onto carpc..
    EDIT: Im also noticing because i havent got a fb attached, my saved buttons are not coming up in the left hand bar so i can go in and modify them?
    Mar 2006
    The configurator cannot really be changed any smaller. There is too much stuff. I really suggest you dev on a full PC.
    The "dummy brain" is called a virtual brain and has been there for well over a year. Its in the debug options.
    Your edit problem is unrelated. Anything will work without a FB attached. Therefore the problem is separate. Which left hand bar?
    Mar 2006
    For the screen size, I just realized you might have meant the size of the graphics and everything once displayed in MDX. If so, then just change the settings in the global graphics settings. You can change it to any resolution size you want.
    Jul 2005
    thanks 2k, im doing skin now... im on full pc doing dev as we speak. but its got no brain attached..
    im in graphic mode adding display buttons.. now ive added mulitple... when i go back to main editing screen and on the left were u double click on display buttons.. none come in, but they still show fine in the graphic editing page?
    Jul 2005
    **** 2k, lol i just added all them buttons, saved... closed.. reopened, opened file... bareee.. nothing..
  1. modify monitor case w/o back
    By Mike12086 in forum LCD/Display
    Last Post: 12-08-2006, 10:04 AM
  2. I'm back! How have you all been?
    By J187 in forum Road Runner
    Last Post: 12-06-2006, 09:58 AM
  3. Replies: 4
    Last Post: 03-23-2005, 11:33 AM
  4. Replies: 5
    Last Post: 01-03-2005, 09:39 PM
