Page 2 of 4 FirstFirst 1234 LastLast
Results 11 to 20 of 35
Thread: Outputs don't have enough power to push relays
  1. #11
    Mar 2006
    Colorado, but Canadian!
    PWM is in the firmware and has been for a while.
    If you cant test it on a windows machine with MDX, I cant debug other people's code.
    1.9in x 2.9in -- 47mm x 73mm
  2. #12
    Jun 2004
    Quote Originally Posted by 2k1Toaster View Post
    Somehow missed the PWM firmware update....
    I'll try it after this weekends' fireworks extravaganza.
  3. #13
    Mo' Programming Mo' Problems
    Sonicxtacy02's Avatar
    Woodbridge, VA
    Blog Entries
    32
    I'm not sure if my question is related or not so i apologize in advance if it doesnt.. but is it possible that either then FB or a relay will weaken its output over time(< 2 years). I have a very strange thing goin on with my lilliput (flickers on/off at start, press touchscreen and the screen turns off). The screen along with my Directed HD Radio is connected to the FB via the FB store relay. I took a multimeter to both sides of the relay. The input (connected to molex for clean 12v) is 12.48 with the engine running and 11.02 is the output. Sounds like quite a drop off doesnt it?
    Live mp3Car Facebook Chat
  4. #14
    Mar 2005
    Yes. SOunds like a bad connection. Also, relays can fail over time.
  5. #15
    Jan 2008
    Dartmouth, MA
    Okay, I just tried on windows. I tried in both MDX using a simple ninja kitty setup and also a setup with a .net app someone posted to the forums a while back with a project name FBDemo. I tried every single output. None of them worked output the right voltage. Also, on output #2, when I plug in a relay its LED light dies until I unplug/replug the fusion brain.
    Overall, unless there is really something I'm missing in the software, I think there is something causing ridiculous resistance somewhere. I'm open to any suggestions though.
    My Nearly Complete Car:
    http://www.mp3car.com/vbulletin/show...ed-car-pc.html
    Micro Control Center... Control Your Car Across the Internet
    http://www.mp3car.com/fusion-brain/1...-internet.html
    Website: (It's a work in progress, really. All my projects have taken me from ever really developing it.)
    http://paulfurtado.com/
  6. #16
    Jan 2008
    Dartmouth, MA
    Any ideas, or am I going to need to send this thing in for repairs?
  7. #17
    High Voltage blk02si's Avatar
    Jul 2005
    Motorcity
    Blog Entries
    1
    My guess is your power source does not have enough amps. Voltage readings are only half the equation of total power consumption, you need to figure out how much current (amps) your source can deliver. 12v 100ma won't close a relay, however 12v 1a will. Heck you can even close a relay with 5v if you have 2.5a behind it.
    12v x 1a = 12w
    or
    5v x 2.5a = 12.5w
    Anyway, you don't have enough current, for example, a car starter operates from 12v, but it sure as heck is not going to turn over with a 12v drill battery.
  8. #18
    Jan 2008
    Dartmouth, MA
    Quote Originally Posted by blk02si View Post
    The relays here actually only draw 70 ma. I tested them with a computer power supply and a multimeter and it worked fine wired directly to the psu through the multimeter and it only drew 70 ma.
    That's what I thought at first too, but then I plugged it into a fully charged 85 AH deep cycle battery. Still nothing. The battery definitely has enough power, it pushes the relay just fine when the relay is wired right to it. The problem is the current is not making it to the outputs on the fusion brain. I've been talking to the fusion brain guys and they're sending me a replacement since it seems like there is definitely something wrong.
  9. #19
    Jul 2005
    Motorcity
    Blog Entries
    1
    That battery should be fine then, looks like your FB is culprit.
    A quick Q for you guys, I am reading these threads because I want to buy a FB. What is the difference between the v4 and the other one that mp3car sells in their store?
  10. #20
    Mar 2005
    v3 has less inputs/outputs and no USB firmware upgrade capability.
  1. 2007 Ford Fusion Carputer (version 2.0)
    By FusionFanatic in forum Show off your project
    Last Post: 04-20-2009, 05:56 PM
  2. Outputs Power Drain
    By sv1cox in forum FB Outputs
    Last Post: 09-25-2008, 11:36 AM
  3. Micro Star Motherboard Problems with Power Switch/BIOS
    By Sidewalksalvage in forum General Hardware Discussion
    Last Post: 06-26-2006, 01:40 PM
  4. DC-DC Car Power for Mac Mini
    By MikeH in forum MacCar
    Last Post: 02-19-2005, 01:13 PM
  5. Replies: 7
    Last Post: 06-15-2004, 10:29 PM
