Results 21 to 30 of 35
Thread: Outputs don't have enough power to push relays
  1. #21
    Feb 2010
    Re:Outputs don't have enough power to push relays
    Hello Everyone,
    I have just received my new FB4 and hooked it up, it seems to be OK except for the low volts on the output when relay is on. I have 12.06 volt at the battery supply and 7.8 volts across relay when it is turned on then. The relay keeps turning on and off. I have the jumpers on the 12 volt side on the board.
    Can someone help? I can not find the solution in the forms, except maybe a bad FB!?
    Russie
  2. #22
    Mar 2006
    Colorado, but Canadian!
    Quote Originally Posted by Russie View Post
    Hello Everyone,
    Russie
    Is it a relay that we provided? Can you test it from a true non-battery source? How many relays are you trying to turn on at once? Does it happen on all ports, or just the one?
    1.9in x 2.9in -- 47mm x 73mm
  3. #23
    Feb 2010
    Relays dropping out
    Thanks for the reply,
    I have tried relays on all ports and all make the relay click on and off.
    I am connected to a good 12 volt dc battery, ( will find a 12 volt a/c adaptor and try that and let you know what happens)
    All the leds blink every few seconds if on 12 volts or USB (no relays connected on USB of course)
    There are 3 leds not working at all!!
    Sorry this is not working as I am very excited as to this will be what I need for my project.
    Any help will be appreciated!!!!
    Russie
  4. #24
    Feb 2010
    Sorry missed your question,
    Yes they are relays from you guys (10 pack with the brain) and I'm only trying one most times and have tried two and they both do the same thing. I have battery volts between relay + and ground but only 7 or 8 volts across relay terminals when on!
    Russie
  5. #25
    Mar 2006
    Is this is a fully functional or semi-defective brain? How are you controlling the relay software wise?
  6. #26
    Feb 2010
    Relays dropping out
    Hi again,
    Yes this suposed to be a fully functional brain not semi defective although it seems like it is one!! I'm controlling the relays with the Fusion control center MDX software.
    My order number is 649 and 650 ( just ordered Jan 30-2010) Just received and only been connected to computer to test run.
    Russie
  7. #27
    Feb 2010
    2K1
    Tried with a power supply and the same thing happens (relay clicks on and off) and leds
    blink every few seconds.
    Is there something you can do for me?
    Russie
  8. #28
    Mar 2005
    Hi again,
    Russie
    We'll swap this out for a new one. Email us. (I think I'm replying to your email now, shoot us an email if not)
  9. #29
    Jan 2010
    This sounds like the problem I've been having. I ordered at the beginning of january. I've tried 3 different computers making sure it's not software, as well as 2 different 12v power sources. I've tried all options and I think there's something going on with the hardware.
    greenman and 2k1:
    I sent a message to you through the website... let me know if sending my brain back to you for replacement is what i need to do.
  10. #30
    Feb 2010
    Russie Back again,
    Have finally received my replacement F4 Brain and connected it to my computer without
    relays and the Leds begin blinking after a few seconds!! Connected two relays and
    12v power supply, relays begin clicking on and off after a few seconds!! Same problem I
    had with my first F4 Brain.
    Can anyone help??
    Thanks Russ
  1. 2007 Ford Fusion Carputer (version 2.0)
    By FusionFanatic in forum Show off your project
    Last Post: 04-20-2009, 05:56 PM
  2. Outputs Power Drain
    By sv1cox in forum FB Outputs
    Last Post: 09-25-2008, 11:36 AM
  3. Micro Star Motherboard Problems with Power Switch/BIOS
    By Sidewalksalvage in forum General Hardware Discussion
    Last Post: 06-26-2006, 01:40 PM
  4. DC-DC Car Power for Mac Mini
    By MikeH in forum MacCar
    Last Post: 02-19-2005, 01:13 PM
  5. Replies: 7
    Last Post: 06-15-2004, 10:29 PM
