Test with this: http://www.fusioncontrolcentre.com/T...estOutputs.zip
See if the problem still happens. I have no solution, since I have found no problem on this side.
My god... whats going on?? I read and read...and theres a lot of people with the same problem... The worst of all is that Im in Chile.. I cant send to you my FBs for replacement... please a real solution for this..
1.9in x 2.9in -- 47mm x 73mm
I have try the file you send me... in one of my two fusion brain I have the input 13 not working... the other one all the inputs flash..
Ill tri with a computer PSU... I have check the voltajes witha true RMS Fluke 89 IV multimeter.... tha PSU its almost perfect... Ihave a variation in voltaje at the third decimal!
and the same happens.. clicks my relays all te time.
Im using a Acer Revo 2GB ram...Atom 230 CPU..
Relays: T9AS5D22-12 AND JQC-3F-L
Anyone has make this work???
Im Using the MDX of course... first I start the sequence..al the led blings one by one (on and off).. except 14th..
with the other button... flash all the leds at same time on and off...
I put a relay in the 14th (led no blinking) and works seems to be bad just the led..
