Page 3 of 7 FirstFirst 1234567 LastLast
Results 21 to 30 of 62
Thread: controlling winamp volume
  1. #21
    Mar 2006
    Colorado, but Canadian!
    Can you sketch up the hardware side. How are the buttons wired, and how are they then connected to the FB?
    1.9in x 2.9in -- 47mm x 73mm
  2. #22
    Mar 2007
    manchester, UK
    i have 3 push to make buttons,
    i have connected each of the 3 buttons with one side connected to + and one side connected to AN
  3. #23
    Mar 2006
    Quote Originally Posted by wilgartw View Post
    You are feeding it directly through? That's a bad idea...
    Connect it up like this:
  4. #24
    Mar 2007
    manchester, UK
    sorry i do not quite understand that.
    currently i have the top half of the daigram.
    are you saying i should connect the [ - ] to the [ AN ] through a resistor? if so, what size resistor?
    ps. why is it a bad idea?
  5. #25
    Mar 2006
    Bad idea because you are leaving the AIN floating when it disconnects. When it floats, it slowly looses charge or keeps other AIN values' charge. You need a way to discharge it to ground.
    Any resistor between like 1kohm and 100kohm is fine.
    EDIT:
    Think of it like this... The FB's analogue input channel is like a big bucket and holds charge with a small leak through the FB itself. You push the button, it charges the bucket for a little bit (like fills it up). Left by itself it slowly empties through the FB. But now you punch a huge hole in it. You push the button, and as long as it is pushed, the FB can read how much is going in. Release the button, the whole bucket gets dumped fast to ground.
  6. #26
    Mar 2007
    manchester, UK
    ok, thanks. i'll go and pick up some 10k ohm resisters tomorrow from maplins.
    next job, changing the volume using a potentiometer.
    can we (you) control windows master volume yet?
  7. #27
    Mar 2007
    manchester, UK
    done all my soldering. the digital switches now do not bleed into the next input.
    thanks for your help so far ...
    "can we (you) control windows master volume yet? "
    i've searched through and although a few people have asked this question, it has never been answered.
  8. #28
    Mar 2006
    sorry. nope not yet. After Vista came out I had to rethink it. Since I run Vista on my dev computer it becomes nearly impossible to make an XP only version and then work on the Vista/7 part later. I'll bump it up in priority
  9. #29
    Mar 2007
    manchester, UK
    that's ok.
    i just didn't want to settle for winamp volume if master volume was available.
    have you any tutorials or pointers for winamp volume. i don't seem to see a delta increment that we had in the pre-MDX version
  10. #30
    Mar 2006
    How do you mean? It's been a long time, I forget what I called things then.
  1. Replies: 16
    Last Post: 01-03-2009, 05:59 AM
  2. Volume leveling DSP plugin for winamp?
    By DeaconC in forum Newbie
    Last Post: 05-01-2008, 01:33 AM
  3. Volume Slider
    By garto in forum Road Runner
    Last Post: 05-13-2007, 01:11 PM
  4. Road Runner Volume Issues ! ! !
    By rewindnottm in forum Road Runner
    Last Post: 03-20-2007, 04:38 AM
  5. Replies: 3
    Last Post: 11-23-2006, 11:14 AM
