Page 4 of 7 FirstFirst 1234567 LastLast
Results 31 to 40 of 62
Thread: controlling winamp volume
  1. #31
    Mar 2007
    manchester, UK
    in order to press up volume in winamp i need to detect when my potentiometer ouputs say an extra 0.1v.
    each time i increase the volts by 0.1v i want to press up arrow
    each time i decrease the volts by 0.1v i want to press down arrow
  2. #32
    Mar 2007
    manchester, UK
    it was something like this:
    #ENABLEHIGHSWITCH#true
    #ENABLELOWSWITCH#true
    #LOWKEYSEQUENCE#DOWN
    #HIGHKEYSEQUENCE#UP
    #LOWMAINWINDOWTITLE#winamp
    #HIGHMAINWINDOWTITLE#winamp
    #HIGHTHRESHHOLD#d0.06
    #LOWTHRESHHOLD#d-0.06
  3. #33
    Mar 2007
    manchester, UK
    any ideas / guidance?
  4. #34
    Mar 2007
    manchester, UK
    hello,
    has any one got any ideas on how to control winamp's volume using a potentiometer?
    i cannot work out how to do the logic that if the voltage from the potentiometre increases by 0.06V it triggers the sending of the up arrow key to winamp.
  5. #35
    Mar 2006
    Colorado, but Canadian!
    Quote Originally Posted by wilgartw View Post
    hello,
    sorry I have been crazy busy...
    I'll whip some code up
    1.9in x 2.9in -- 47mm x 73mm
  6. #36
    Mar 2007
    manchester, UK
    thank you, sorry didn't mean to be pushy, it's just i have the unit out of the van to do this so i am keen to get it all working and back in again.
  7. #37
    Mar 2007
    manchester, UK
    bump (?)
  8. #38
    Mar 2006
    sorry I've been really distracted lately. Ill get it to you before I go to sleep tonight
  9. #39
    Mar 2006
    Ok, first here is the code I based it off of. This is from the source code to Version 2 software:
    Code:
                        else if (AIDynamicButtonList[i].TypeString.Equals("POTENTIOMETER"))
                            double vtminus1 = AIDynamicButtonList[i].PreviousRawValue;
                            double vtnow = AIDynamicButtonList[i].CurrentRawValue;
                            bool goingup = true;
                            double diff = vtnow - vtminus1;
                            if (diff < 0)
                                goingup = false;
                            else if (diff > 0)
                                goingup = true;
                            if (goingup && diff > AIDynamicButtonList[i].HighSwitchValue)
                                //There is less voltage, and the change is greater than the histeresis, so do the up command
                                if (AIDynamicButtonList[i].LOW_KeySequenceString.Equals("*SWITCHOUTPUT*"))
                                    SwitchOutputFromAnalogue(i, false);
                                else
                                    SendAKeySequenceToAProgram(AIDynamicButtonList[i].LOW_KeySequenceString, AIDynamicButtonList[i].LOW_MainClassString, AIDynamicButtonList[i].LOW_MainWindowString, AIDynamicButtonList[i].LOW_SubClassString, AIDynamicButtonList[i].LOW_SubWindowString);
                            else if ((!goingup) && diff < (-1) * AIDynamicButtonList[i].LowSwitchValue)
                                //There is more voltage, and the change is greater than the histeresis, so do the down command
                                if (AIDynamicButtonList[i].HIGH_KeySequenceString.Equals("*SWITCHOUTPUT*"))
                                    SwitchOutputFromAnalogue(i, true);
                                else
                                    SendAKeySequenceToAProgram(AIDynamicButtonList[i].HIGH_KeySequenceString, AIDynamicButtonList[i].HIGH_MainClassString, AIDynamicButtonList[i].HIGH_MainWindowString, AIDynamicButtonList[i].HIGH_SubClassString, AIDynamicButtonList[i].HIGH_SubWindowString);
    So I took that, and made it into logic statements. I havent tested it or anything, but it should work.
    My dad has been in town these past 2 weeks so I have been doing a lot of family things ontop of everything else. He leaves tomorrow, so I will have some more time to spend.
    XML: http://www.fusioncontrolcentre.com/T...figuration.xml
  10. #40
    Mar 2006
    I should note that the hysteresis value is set large right now and the do statement that sends a U is when you want the volume to go up, and the one for D is for down. You will need to change those to the real then/do statements for controlling winamp.
    Also make sure in the one that does multiplication it stays "-1" and not just "1". I found a bug in the config that pops up some times, but I need to get to sleep as I need to wake up in less than 2 hours to see my dad off. I'll try to fix the configurator bug shortly...
    -- Nick
  1. Replies: 16
    Last Post: 01-03-2009, 05:59 AM
  2. Volume leveling DSP plugin for winamp?
    By DeaconC in forum Newbie
    Last Post: 05-01-2008, 01:33 AM
  3. Volume Slider
    By garto in forum Road Runner
    Last Post: 05-13-2007, 01:11 PM
  4. Road Runner Volume Issues ! ! !
    By rewindnottm in forum Road Runner
    Last Post: 03-20-2007, 04:38 AM
  5. Replies: 3
    Last Post: 11-23-2006, 11:14 AM
