Page 6 of 7 FirstFirst 1234567 LastLast
Results 51 to 60 of 62
Thread: controlling winamp volume
  1. #51
    Mar 2007
    manchester, UK
    i am running 5.0.0.234
    yes the vote button works on the digital button.
    the graphic also shows the correct voltage reading for the id "volume"
  2. #52
    Mar 2007
    manchester, UK
    doesn't low or high have to be -0.06? or something similar? won't this try to trigger both of them at once?
  3. #53
    Mar 2006
    Colorado, but Canadian!
    Quote Originally Posted by wilgartw View Post
    no because the code multiplies the high by -1 before comparing.
    1.9in x 2.9in -- 47mm x 73mm
  4. #54
    Mar 2007
    manchester, UK
    ok, i tried it with and without anyway, still no joy.
  5. #55
    Mar 2007
    manchester, UK
    tried changing my digital button to fire "UP" too, and this works so nothing wrong with the button presses in winamp...
  6. #56
    Mar 2006
    post your button code
  7. #57
    Mar 2007
    manchester, UK
    it's in the code above. "Root Function #3" just above the custom scripts
  8. #58
    Mar 2006
    Ok now you have me confused...
    function #3 is reading an analogue input, and then sending the key to winamp. That is a hardware button.
    A display button is a software button that is in the GUI section. Shows up on the screen and you click it. This is what I am referring to for testing. If you can push the GUI button and make the volume change, then there is a problem with the logic below. If it doesnt work from here then the problem is not with the logic.
    However, you said that Logic #3 works now? "UP" and "DOWN" are the arrow keys on the keyboard. My guess is another application has already hooked those since they are so common. Use "NUM8" and "NUM2" (the keypad numbers).
  9. #59
    Mar 2006
    Quote Originally Posted by 2k1Toaster View Post
    This actually might the be the problem. I forgot to mention (sorry ) that the analogue input channel needs to have a history value of at least 2, one for the current value and the other for the previous value otherwise it can't compare anything, so it just errors out.
    Code:
          <iochannel id="volume" port="0" brain="radio" type="analogue_input">
            <options history="0" auto_average="true"></options>
          </iochannel>
    to
    Code:
            <options history="2" auto_average="false"></options>
          </iochannel>
  10. #60
    Mar 2007
    manchester, UK
    Code:
          </iochannel>
    to
    Code:
          </iochannel>
    yep that works!!!
    hurrah!
    just one more thing
    i cannot get enough increments on my pot to send enough up keys to go from 0 to 100% volume.
    i have set the minimum_delta_vote_time="0.01" and low/high="0.005"
    which in theory should give me 1000 key presses. if i rotate the pot in 1/100ths of a second, but no matter how slowly i turn it it only travels at most 2/3rds of the volume range.
    i have tried quite a few different values. some better, none enough. can i get it to send three vote keys per fire?
    winamp seems to need about 60 key presses for it's full range. if i can get it to send three, i only need 20 fires, so can set the low/high to 0.25 (5v/20)
  1. Replies: 16
    Last Post: 01-03-2009, 05:59 AM
  2. Volume leveling DSP plugin for winamp?
    By DeaconC in forum Newbie
    Last Post: 05-01-2008, 01:33 AM
  3. Volume Slider
    By garto in forum Road Runner
    Last Post: 05-13-2007, 01:11 PM
  4. Road Runner Volume Issues ! ! !
    By rewindnottm in forum Road Runner
    Last Post: 03-20-2007, 04:38 AM
  5. Replies: 3
    Last Post: 11-23-2006, 11:14 AM
