View Poll Results: Enclosure or Case for the Fusion Brain
Voters
23. You may not vote on this poll
  • We don't need no stinking cases
    7 30.43%
  • I would like a plastic case designed specifically for the Fusion Brain
    13 56.52%
  • Option 2 is good and all, but too expensive for my tastes
    2 8.70%
  • I would like a metal case designed specifically for the Fusion Brain
    3 13.04%
  • Option 4 is good and all, but too expensive for my tastes
    3 13.04%
Multiple Choice Poll.
Page 1 of 3 123 LastLast
Results 1 to 10 of 26
Thread: Enclosure for Fusion Brain. Would you want one?
    Mar 2006
    Colorado, but Canadian!
    Question Enclosure for Fusion Brain. Would you want one?
    Hello everyone,
    We are trying to get a feeler for if you guys (and gals) would like to have an enclosure or case made available for the Fusion Brain Version 4. It would most likely be plastic, but could be metal I guess.
    These sorts of cases arent cheap though, so we cant go run off a bagillion and hope you want them, so we need some feedback.
    Would $12 to $15 be worth it for a plastic case custom designed for the Fusion Brain? It would have standoffs built in inside so that it would mount no fuss needed. There would be holes for the DC jack and USB jack. There would also be holes (or maybe punchouts) for the digital outputs and analogue inputs. So a custom solution.
    We can also do metal but the pricing for that is through the roof. So far we received quotes of close to $70 a piece, so I would like to avoid that...
    Is this something you would buy?
    1.9in x 2.9in -- 47mm x 73mm
    Jun 2004
    Although I would like to have one, I don't think I'd buy it. The custom nature of the FB doesn't lend itself to an all-in-one solution. How many CarPC or other automation projects DON'T require taking a dremel to an enclosure?
    You can't use the fusion brain completely by itself, so it's kinda dumb to have it's own case. I have one sitting on my desk (styrofoam coffee cup as an insulator...) & another in a $3 plastic toolbox with screwed/glued motherboard standoffs. Either way, i have to have at least one other "box" nearby to contain the power & computer. I just don't see the benefit vs the cost (even at ~$10)
    Mo' Programming Mo' Problems
    Sonicxtacy02's Avatar
    Woodbridge, VA
    Blog Entries
    32
    would you be designing cases for all versions? I actually started coming up with a design for a V3 case
    Live mp3Car Facebook Chat
    Mar 2006
    Quote Originally Posted by Sonicxtacy02 View Post
    Not unless we can find a cheap manufacturer. It is nearly $500 to setup a new case design, then ontop of that there is the price per unit. Since we dont sell the V3 anymore and most people have already done something with it, I dont see the overall benefit. Might be able to make it V3 & V4 compatible, but that would double the size of the case and make it look sort of wonky...
    Woodbridge, VA
    Blog Entries
    32
    understood.. i'll just go ahead with my concept then. I've got a perfect sized plastic case i just have to find someone to handle the rather precise cutting.
    Jun 2004
    Can't beat a razor blade, heated if need be. Just use outer connectors with a lip that will hide the cuts. I use hot glue to hold the connectors in. Outside, it looks professional, inside, well "half-assed" is my description but, half-assing makes the world go 'round.
    Mar 2006
    Better than the soldering iron I normally use to cut plastic (I use it only to cut plastic since I cant find any new tips that work in it)
    Jun 2008
    I would be against it personally, I will be picking one up soon and although a case is a good idea, for this hobby most people are well equipped to make something for it to fit just what they are doing for much cheaper.
    Variable Bitrate csfile's Avatar
    Feb 2009
    I wouldn't mind paying $12-15 for a plastic case. I know some people here are well equipped to make one, but I'm not one of them. I'm currently using a small tupperware box that I just drilled some holes in. Pretty ghetto.
    Mar 2007
    manchester, UK
    i wouldn't buy one now (living in the uk, considering the extra shipping)
    if i had the choice when buying the original i would've thrown one in the mix.
  1. *NEW* USB Input/Output Board -- Fusion Brain
    By 2k1Toaster in forum Fusion Brain
    Last Post: 02-22-2010, 03:33 AM
  2. Replies: 17
    Last Post: 01-16-2009, 10:48 AM
  3. Replies: 3
    Last Post: 09-23-2008, 10:00 PM
  4. How to add a Fusion Brain instance to your configuration file
    By 2k1Toaster in forum FB Documentation and Tutorials
    Last Post: 06-07-2008, 09:42 AM
  5. Fiberglass and MDF sub enclosure walkthrough
    By monkeyracer in forum Fabrication
    Last Post: 05-19-2008, 03:55 PM
