Page 5 of 6 FirstFirst 123456 LastLast
Results 41 to 50 of 51
Thread: Fusion Brain CarPC LT1 dash gauges project
  1. #41
    Constant Bitrate ACCLR8N's Avatar
    Apr 2009
    Davisburg, MI
    I have a copy of the evaluation version of EFILive on my laptop as a matter of fact. I disagree on the budget issue as it is $179US for a real license. It didn't display half of what I wanted for a virtual dash. It's been fun learning all this stuff. I just started last June.
    Segue: FB MDX Ride Runner auto head lights you say?
  2. #42
    Variable Bitrate Grrrmachine's Avatar
    Sep 2005
    Warsaw, Poland
    Whilst there are systems out there that can read all that sort of data from certain ECUs through the OBD I socket, because OBD I isn't actually a standard system, the amount of data that can be read for each engine is specific. For my E30 BMW, I'm having to build my own datalogger, and using a Fusion Brain, a few potentiometers, and some cable splicers, I'm getting speed, tacho, fuel and coolant temp for a hell of a lot less than $179!
  3. #43
    Mar 2010
    Perth
    If you know where to look, you can get the pro version for free, with an expiration date of january 30, year 3000
  4. #44
    Nov 2003
    Is there any way to us download the configuration files for MDX? Thanks!
  5. #45
    Apr 2009
    Davisburg, MI
    PM'd
  6. #46
    Variable Bitrate nemo1's Avatar
    Jun 2006
    Hi ACCLR8N, i'd like to have a copy of the configuration files for MDX as well....Thanks
  7. #47
    Jul 2007
    HI, Thanks for sharing such nice project.. Could you pls share this project files also......
    Regards..
  8. #48
    Apr 2009
    Davisburg, MI
    PM me your e-mail address or an FTP site login and I'll send them.
  9. #49
    Jun 2006
    PM sent...TIA
  10. #50
    Jun 2006
    I have a few questions.
    - when measuring voltage, how could we know the range? For example if measuring RPM or Speed?
    - I've read a page back about using capacitors to remove noise, what values(farad,voltage) of capacitors do we choose? and should it be connected in series or parallel?
  1. Replies: 86
    Last Post: 02-23-2011, 06:31 AM
  2. *NEW* USB Input/Output Board -- Fusion Brain
    By 2k1Toaster in forum Fusion Brain
    Last Post: 02-22-2010, 02:33 AM
  3. Fusion Brain and Auto HVAC. h3rk where are you?
    By Willn in forum Fusion Brain
    Last Post: 04-17-2009, 09:08 AM
  4. need help on fusion brain 25A Relay wireing
    By wethecom in forum Power Supplies
    Last Post: 09-01-2008, 02:59 PM
  5. The Vectra CarPC / CarPuter Project v2
    By ccsnet in forum Show off your project
    Last Post: 08-29-2005, 05:46 PM
