Page 6 of 6 FirstFirst 123456
Results 51 to 52 of 52
Thread: Fusion Brain CarPC LT1 dash gauges project
  1. #51
    Constant Bitrate ACCLR8N's Avatar
    Apr 2009
    Davisburg, MI
    I sent you an Excel sheet with my wiring notes and frequency to voltage calculations.
    0.1uF in parallel.
  2. #52
    Feb 2014
    Hey ACCLR8N! So I'm trying to do something similar to what you have achieved here but adapt it to work in Android. Your work is the most documented conversion I could find thus far but is still a little confusing to a newbie like me. So far I've looked at Fusion Brain, Phidgets, and the Arduino for potential boards but I'm not sure which is best.
    I've got a 1993 Jurassic Park Ford Explorer replica and all I need to read is oil, fuel, temp, voltage, and speedo since I'll just get rid of the tach and relocate all my dummy lights. Once I find the resistor values for all the gauges (working on that!) is it simply a matter of adding the correct resistors to each wire before tapping into the microcontroller? Could I take a look at your wiring notes?
    Any help would be greatly appreciated. Thank you!
  1. Replies: 86
    Last Post: 02-23-2011, 06:31 AM
  2. *NEW* USB Input/Output Board -- Fusion Brain
    By 2k1Toaster in forum Fusion Brain
    Last Post: 02-22-2010, 02:33 AM
  3. Fusion Brain and Auto HVAC. h3rk where are you?
    By Willn in forum Fusion Brain
    Last Post: 04-17-2009, 09:08 AM
  4. need help on fusion brain 25A Relay wireing
    By wethecom in forum Power Supplies
    Last Post: 09-01-2008, 02:59 PM
  5. The Vectra CarPC / CarPuter Project v2
    By ccsnet in forum Show off your project
    Last Post: 08-29-2005, 05:46 PM
