Results 1 to 4 of 4
Thread: fuse size
    Jan 2005
    fuse size
    simple question what size fuse should I use to fuse the fusion brainV3 when using it on un regulaqted power?
    Mar 2006
    Colorado, but Canadian!
    Quote Originally Posted by yonu View Post
    There is a built in thermal fuse. Each relay takes about 500mA so just add them up that way. You really dont need an external fuse.
    1.9in x 2.9in -- 47mm x 73mm
    Jan 2005
    cool thanks that is what i needed to know I wasn't sure so I gihured it was better to ask
    Aug 2008
    Decatur Illinois
    Here is something to consider from the aviation world. First everything has a fuse or circuit breaker. Second, the fuse (or breaker) size is dependent on the wire size. The fuse is to protect the wiring, not the component. This really makes sense, the first time you short out a wire and burn up a wire bundle or start a fire. Absolutely makes no difference what is connected to the wire. Just for your consideration.
  1. Replies: 2
    Last Post: 08-11-2009, 07:46 PM
  2. Replies: 3
    Last Post: 08-13-2006, 02:13 PM
  3. Size Of ANL Fuse?
    By bird in forum Car Audio
    Last Post: 05-11-2006, 03:15 AM
  4. Opus 120, 12V line from battery, what size fuse?
    By 01black_ac in forum Power Supplies
    Last Post: 04-12-2006, 12:53 AM
  5. low amp fuse blowing in MX radio adaptor
    By march09 in forum Car Audio
    Last Post: 01-06-2006, 06:53 PM
