Results 1 to 5 of 5
Thread: Using FB sensors in *combination* with OBDII data?
    Sep 2009
    I have an OBDII car, but I'm interested in using a FB setup to incorporate oil temperature and oil pressure sensors, which the car does not have from the factory. Ultimately, I'd like to be able to display and log everything together, either by incorporating the FB inputs into one of the typical OBDII dash apps, or by incorporating selected OBDII data into a FB app. Might also like to tie in exhaust gas temps, or even AFR at some point.
    Has anyone done anything like that? I'm not even sure from which end I should start thinking about this. Seems like I can't be the only one, since in all but the newest cars OBDII data is usually missing some big, critical engine health information.
    Constant Bitrate ACCLR8N's Avatar
    Apr 2009
    Davisburg, MI
    It will do the sensors you mentioned. There's quite a bit about controls (buttons) back and forth with other software, but I haven't seen anything about sharing data (like an odometer function).
    http://www.mp3car.com/vbulletin/fb-s...ig-update.html
    SuperMod - OBDII GPS Logger forum
    Mar 2009
    Los Angeles
    First question, are you *sure* it doesn't have an oil temp sensor? My mini doesn't have a temperature gauge on the dash [grrr grumble grr grumble what the hell, mini], but it does have a temperature sensor in the engine, reported through OBDII.
    Secondly, I'm not sure how you'd proxy them together, and it doesn't work on windows at the moment, but... obdsim can be used to proxy FBD values into your system as OBDII data
    Gary (-;
    OBDGPSLogger, for logging OBDII and/or GPS data
    OBDSim, an OBDII/ELM327 software simulator
    mp3car forums: obdgpslogger, obdsim
    Sep 2009
    Thanks guys, these links are helpful. I'll post some updates if I'm able to make any progress with this.
    And yes, I'm pretty sure about the oil pressure. In any case, I'm quite certain the stock OBDII doesn't report EGT, brake position, or any number of other things I might conceivably like to try feeding into the FB.
    Variable Bitrate nemo1's Avatar
    Jun 2006
    Quote Originally Posted by chunkyks View Post
    Gary (-;
    I am trying to use OBDi with FB. From the links of your post, I've noticed that fbd is linux based and i've found windows based obdsim from the links. What do I do for the linux portions? I'm confused at the linux portion.
  1. Replies: 412
    Last Post: 11-09-2011, 10:50 AM
  2. various sensors...
    By abyssdj in forum FB Sensors
    Last Post: 10-30-2007, 07:35 PM
  3. GoogleEarth GPSR Tracking
    By briefnotion in forum GPS
    Last Post: 09-11-2007, 08:32 PM
  4. VOICES Traffic Data
    By stevieg in forum V.O.I.C.E.S
    Last Post: 05-31-2004, 09:24 PM
