The USB ID probably changes?
Seems like every time I try to install my fusion brain on a new computer I always have some sort of problem with Ride Runner and RRfusion. Currently I have the fusion brain set up with my laptop and when I tried to copy everything over to my carpc once again it doesn’t work. The fusion brain software sees the fusion brain and it is “working properly” in the device manager.
I am using the same version Ride Runner and RRfusion in my car pc as I was in my laptop. So why is the fusion not working with ride runner?? Any ideas?
Thanks!!
right, sorry should have been more descriptive,
when I said the fusion brain software sees the fusion brain, i ment on the car pc
If MDX sees it, then our part is working. The problem is in your configuration of RRFusion which we do not support.
1.9in x 2.9in -- 47mm x 73mm
Right, Your part is working, No complaints there.... Was hoping to get some help with the RRfusion.
