Results 1 to 5 of 5
Thread: Fusion outputs and hibernate/resume
    JiC
    JiC is offline
    Sep 2008
    I'm using 1 output to control a relay that powers my amps remote wires.
    I have the default of the output to off
    I'm using the ExecTBL.ini of RR to send commands:
    "ONRESUME","fusion_vote_AmpON"
    This command works A-OK, only problem is when coming back from hibernate the fusion brain restores the last state of the output (on) before my PC is ready (and before AmpON gets called) and I get a big screech and thump. It works fine if I manually turn off the output before hibernating.
    I try using this command:
    "ONSUSPEND","fusion_vote_AmpOFF"
    but it throws an error.
    Any ideas or input from anyone would be much appreciated!
    JiC
    JiC is offline
    Sep 2008
    I got impatient and just added ign,acc inputs to the fusion brain (3.3k and 10k voltage divider). When they are both 0, I turn the output off.
    Works well enough for now. Plus I like having a volt-meter. Should I be worried about voltage spikes or anything like that?
    Mar 2006
    Colorado, but Canadian!
    Not sure why I never got an email about this thread until today, but sorry I missed it.
    The divider will work just fine, and like you said, you get the nifty voltmeter too. Spikes would be a worry, as with all non-isolated circuits. If you are handy with electronics, a simple unity gain opamp after the divider, or an optoisolator would be preferred. If you would rather just buy something, then we sell a 4channel isolator with built in divider so you would just hook the +12v inputs direct to it, then direct to the FB.
    But you shouldn't have any problems. Yet again, your house shouldn't burn down yet we all have fire extinguishers (I hope ).
    1.9in x 2.9in -- 47mm x 73mm
    JiC
    JiC is offline
    Sep 2008
    Thanks for the info! I'm a computer engineering student, we haven't used opto-isolators yet but this sounds like a fun way to learn.
    Mar 2006
    mouser.com has some good products for prototyping at reasonable rates and cheap shipping inside the US.
    Just test your circuits with bench supplies and multimeters before you go hooking it up to the Fusion Brain!
  1. Disable hibernate/resume error message?
    By b8bboi in forum WinNT Based
    Last Post: 07-25-2010, 07:00 PM
  2. Replies: 1
    Last Post: 05-20-2008, 05:08 PM
  3. resuming music playback on hibernate/resume?
    By GreenBeast in forum Mobile Impact
    Last Post: 08-08-2005, 12:14 PM
