Results 1 to 10 of 14
Thread: Analogue inputs acting funny..
    Variable Bitrate rEegLer's Avatar
    Jul 2008
    Mechanicsburg, PA
    Hey guys,
    I was just about to put my CarPC in my car but I thought I'd test my FB with my simulated steering wheel control circuit and I hooked everything up and noticed that my other ports were measuring a voltage but nothing was there. I took it out and setup a test config file that showed all the ports and their voltages. This is what I got:
    In this pic, I have 5v connected to port 1 (Port 1 on FB, Port 0 in configurator) and the other ports are reading these voltages. You will notice that the voltages decrease as the port increases, kinda interesting.
    Anyone know why this is? Do I have a fried board? I don't remember doing anything to fry it but who knows. In an attempt to get it to work, I pressed the reset button and switched off power and turned it back on and it said that it was version 3 not 4 when I reinstalled the drivers (I was desperate ).
    Any help would be greatly appreciated!
    Love
    Raw Wave Rob Withey's Avatar
    Apr 2000
    Bedfordshire, UK
    Jul 2008
    Mechanicsburg, PA
    Thanks, wasn't sure what to search for!
    Love
    Mar 2006
    Colorado, but Canadian!
    Yup, it is normal. Just left over charge on the sampling capactior. Once you hookup another sensor, it will read correctly since it wont float anymore.
    1.9in x 2.9in -- 47mm x 73mm
    Mo' Programming Mo' Problems
    Sonicxtacy02's Avatar
    Woodbridge, VA
    Blog Entries
    55
    Quote Originally Posted by 2k1Toaster View Post
    im not sure i ever saw an answer to this question, but is adding a jumper to blank inputs a safe way to zero them out? Will it do damage to the FB?
    Live mp3Car Facebook Chat
    Mar 2006
    Quote Originally Posted by Sonicxtacy02 View Post
    Why zero them out? If they aren't in use, then you aren't doing anything with them and they have the parasitics. As soon as you attach something to prevent them from floating such as a sensor or aything where you will use the input it will measure accurately. It is only apparent when measuring nothing.
    If you really want to make it go away, then (assuming you are using consecutive analogue inputs for your array of sensors) jumper between the AIN pin and GND. Be careful not to short power and ground as this will signal destruction of your Fusion Brain.
    Jul 2008
    Mechanicsburg, PA
    Yea it was just a little weird, that's all. Just making sure my FB wasn't damaged.
    One quick question. When I hook up ~12V to the FB (and change the jumpers previous to the powerup), nothing really works. No AN inputs work and my MDX program errors out with .Net. When I hookup 12v while it is USB powered, everything works fine, AN inputs and digital outputs. Is this bad? I couldn't find anything written against this in the manual.
    Love
    Mar 2005
    Quote Originally Posted by rEegLer View Post
    It shouldn't happen. It isnt bad to use both power sources, but it's not really good practice and can induce ground loops, among other things. Can you take a picture of the jumpers in each config?
    Constant Bitrate ACCLR8N's Avatar
    Apr 2009
    Davisburg, MI
    I'm running a jumper in front of each of my sensor inputs (every other port). The residual charge was throwing off all my sensors to some degree Tach, Speedo, oil pressure, fuel level. Even my digital signals such as check engine and alternator I have on on SPDT relays shunted to ground when off. http://www.mp3car.com/vbulletin/fusi...capacitor.html
    Jul 2008
    Mechanicsburg, PA
    How accurately can the fb measure voltage? I have my steering wheel controls hooked up hookep up through a voltage divider and when I push one button, I'll get a voltage of 2.49577 for example but it flickers between that and 2.49166 somewhat randomly. I haven't tried the every-other port idea but I'm also not sure if it's the quality of my components or electrical noise.
    Love
  1. Analogue inputs into CarPC - eg Batt Volts?
    By Bammo in forum General Hardware Discussion
    Last Post: 06-07-2009, 04:26 PM
  2. Fusion Brain V4 Digital Inputs
    By malcom2073 in forum Fusion Brain
    Last Post: 02-14-2009, 12:16 PM
  3. Head Units with RCA inputs
    By bitwaba in forum Car Audio
    Last Post: 06-04-2008, 03:30 AM
  4. CF 1,7 acting funny
    By suburbank2500 in forum Centrafuse
    Last Post: 08-20-2006, 11:56 PM
