Page 2 of 2 FirstFirst 12
Results 11 to 19 of 19
Thread: stupid relay question
  1. #11
    Jan 2005
    ok a couple of questions.
    if the led on the board comes on then i assume the output should work correct?
    and
    second if I just a standard automotive relay then how should I have it wired?
    Thanks,
    Yonu
  2. #12
    Mar 2006
    Colorado, but Canadian!
    Quote Originally Posted by yonu View Post
    As long as the ULN chip is not blown, it is a fair assumption.
    Thanks,
    Yonu
    Coil to the two ports, then the other side to whatever you are powering.
    1.9in x 2.9in -- 47mm x 73mm
  3. #13
    Jan 2005
    ok so based on what you put about the relay coils is this diagram correct?
    and how do I know if the ULN chip is blown or not?
    Thanks,
    yonu
  4. #14
    Jan 2005
    not trying to be a jerk but some kind of answer would be nice
  5. #15
    Mar 2006
    Yes the diagram is correct. Make sure the relay doesnt pull to much to activate its coil. Less than 500mA is required, half of that is recommended if you are doing a lot.
    Like I said before, the relays in our store are plug and play.
  6. #16
    Jan 2005
    yes I understand the relays in the store are plug and play but i have a 150 automotive relays with a 150ma coil so I would prefer to use them instead of buying more relays
    Thanks for the reply,
    yonu
  7. #17
    Feb 2010
    It's been my experience that if your using a standard 30/40 amp automotive relay the fusion brain does not have enough current to charge the coil. I've had to install small relays similar to the one's Fusion Brain sells in between the brain and my automotive relays.
    Hope this helps you.
  8. #18
    Mar 2006
    It can provide 500mA to close the coil, which is generally enough to close the coil. We know it works with our relays, and if you buy an automotive relay elsewhere makesure that the coil doesnt draw too much current.
  9. #19
    Jan 2005
    ok thanks will let you know as soon as I get it running again.
    I changed to windows 7 and can't get mdx to work the configurator to load but not the mdx program. i don't get errors it just doesn't load
    Thanks,
    yonu
  1. stupid question time about pci slots
    By luna123black in forum Newbie
    Last Post: 10-20-2009, 07:54 PM
  2. Question about a relay?
    By atrixstars in forum Car Audio
    Last Post: 10-10-2009, 04:20 PM
  3. stupid paranoid question
    By Dennis5587 in forum LCD/Display
    Last Post: 06-19-2006, 05:58 PM
  4. Question about relay interface boards
    By ndenaway in forum General Hardware Discussion
    Last Post: 03-14-2006, 07:56 PM
  5. Will someone help me program my relay control module
    By cproaudio in forum Software & Software Development
    Last Post: 09-04-2002, 05:50 AM
