Results 1 to 10 of 19
Thread: stupid relay question
    Jan 2005
    ok using a standard automotive relay with the fusion brain should I be activating the positive or negative coil using the fusion brain I have finally gotten around to starting the hard wiring of the items my fusion brain will control but i can't get the relays to trigger I know it is switched ground on the digital outputs but I can't get the relay to trigger.
    so basically what I am saying is Help
    Thanks,
    Yonu
    North of the land of Hey Huns
    Jun 2004
    Westminster, MD
    How do you have it hooked up? It should be from the positive rail of the FB, through the relay coil, into the digital output (I think)
    RevFE
    My Shop
    Jan 2005
    ok now I am confused sorry that just doesn't make any sense to me
    sorry
    Jan 2005
    oh and sorry I forgot to include how I have it hooked up here is the diagram of how i have it hooked up I am using the switched ground and i am not using the fusion brains 12v+ to power the relay
    Constant Bitrate ACCLR8N's Avatar
    Apr 2009
    Davisburg, MI
    Your diagram is correct. The switched grounds on the FB are the inner pins. The FB on the same ground as the 12V you are using? The FB power jumpers set to 12V power and not USB power?
    Jan 2005
    it is a v3 FB so i can't change the power and yeah it is on the same 12v ground at least according to my voltmeter
    Jan 2005
    ok here is a odd one I decided to try something so i disconnected the power from the brain and it stayed on via the usb power I would assume this is not normal for a v3 fusion brain?
    Jan 2005
    I found the answer to the power staying on issue so I am going to double check my relay and see what is going on because if i unplug the relay the FB cuts off if i reconnect it it turns back on.
    so should I have a diode on the line to the digital output on the Fusion brain?
    Jan 2005
    ok I double checked the relay and it is right i tried 2 others to make sure it wasn't a bad relay I even tried a diode in the line the diode stops it from turning on if i remove power however it doesn't turn on the relay
    so if anyone has an idea i would be most greatful,
    yonu
    Mar 2006
    Colorado, but Canadian!
    If you are using our relay, you just plug it in and it works.
    You need to connect +12v to one side of the coil and then the other side to the ground switched port on the Fusion Brain.
    The port will always show 0v or NC (Not Connected) when on or off respectively. It will never show the 12v or anything.
    1.9in x 2.9in -- 47mm x 73mm
  1. stupid question time about pci slots
    By luna123black in forum Newbie
    Last Post: 10-20-2009, 07:54 PM
  2. Question about a relay?
    By atrixstars in forum Car Audio
    Last Post: 10-10-2009, 04:20 PM
  3. stupid paranoid question
    By Dennis5587 in forum LCD/Display
    Last Post: 06-19-2006, 05:58 PM
  4. Question about relay interface boards
    By ndenaway in forum General Hardware Discussion
    Last Post: 03-14-2006, 07:56 PM
  5. Will someone help me program my relay control module
    By cproaudio in forum Software & Software Development
    Last Post: 09-04-2002, 05:50 AM
