Results 1 to 5 of 5
Thread: Easiest way to check outputs
    May 2010
    I have a V3 FB and i am finally trying to get the thing working. I have the temp sensor working and converting to Fahrenheit correctly, but I am having issues with the digital outputs. I have read in the posts that I will never read a voltage across the pins so I tried to read continuity across the grounds to see if it is switching correctly but I get nothing there. I don't have one of the stores relays but I do have other relays I can use. What can I do to check it? The LED's do light to indicate the outputs are active but that is all.
    Mar 2006
    Colorado, but Canadian!
    Connect your voltmeter between + and the output ground pin. When the output is off you will read nothing (as in open line, not connected). When the output is on, you will read + (minus a little bit of course).
    1.9in x 2.9in -- 47mm x 73mm
    May 2010
    Ok, I did some more checking on the board today. There is something really screwed up here. When I choose output 0 the LED lights for output 0 but I read voltage on output 7. All my outputs seem to work but they are all over the place not on the correct output, except for outputs 8-11 they are correct. Any ideas on this one, atleast I know the fusionbrain can work I just have to remap the outputs and never look at the on board LEDs.
    May 2010
    Ok, I just found the FAQ stating V3 LEDs are messed up.
    http://www.fusioncontrolcentre.com/F...rdware_004.php
    Mar 2006
    Yup, that was a V3 problem. Fixed in future versions.
  1. Bloomin' alternator whine
    By Vodkapete in forum Car Audio
    Last Post: 05-03-2007, 06:25 PM
  2. Feature Request: Auto check for gps data
    By Sonicxtacy02 in forum WhereIsMyGPS Online Tracking
    Last Post: 07-31-2006, 07:50 PM
  3. Just an FYI: CHECK THE VOLTAGES!
    By dbzeag in forum Power Supplies
    Last Post: 06-13-2006, 04:22 PM
  4. C.A.M.P. Project revealed! please check it out
    By crazyshaxs in forum General Hardware Discussion
    Last Post: 04-12-2001, 08:52 PM
