Results 1 to 5 of 5
Thread: Is there any dehumanisation haw to
    Jun 2010
    Hi all
    I joust seen the Fusion brain and I think its a rely nice unit but I have a question.
    Why is the site http://www.fusioncontrolcentre.com/ down all the time?
    Haw due I get my aps uploaded to the fusion brain?
    Is there any documentation haw to
    Is there still been added new things to the product or no development
    Peter
    Fusion Brain Creator
    Mar 2005
    I haven't noticed our site having issues, or heard anything else.
    Get your aps uploaded? Not sure what you mean here.
    There are plenty of how-tos, right here in this forum.
    We're still developing.
    Jun 2010
    Ok thanks greenman.
    I would describe what I would like to due and hope to get feedback if its possible.
    My house is controlled by IHC (intelligent house computer) but I think the software sucks.
    So my plan is to control:
    Light 20 in/output (wall touch buttons)
    flour heating 6 sensors and 6 valves
    Outdoor light using sensors and time like on at 23.00 off at 24.00
    Voltage is 24V
    Also is it possible to make marks(bit) like a set and reset and use them in the program.
    For a living I work with PLC Siemens/Allen Bradley but I due not program C#
    Is there a chance I will get this to work using Fusion Brain
    Thanks a lot
    Peter Jensen
    Jun 2004
    Quote Originally Posted by peter_jensen View Post
    Ok thanks greenman.
    Voltage is 24V
    Thanks a lot
    Peter Jensen
    Fusion Brain + PC = PLC; The brain is useless by itself, you don't "load" anything to it, you just communicate with it.
    MDX software ~= RSLogix5000 (last PLC software I used, many moons ago), similar to ladder logic programming, but more graphical.
    You don't need to program in C to use MDX, it's graphical programming "language". Ever use LabView? That's the closest comparison I can think of.
    There's also a Visual Basic program floating around that's very easy to communicate with the brain, but harder on the GUI side (at least for a touchscreen - it's very easy for mouse-click buttons & label info). if you're using buttons/switches, it might be easier to use Visual Basic (even with the learning curve). If I can use VB, anybody can.
    MDX will interface with a touchscreen easily, I would suggest reading up on that & downloading it to try (you can use the virtual brain to see how things work)
    You can do what you are talking about. Multiple brains & a ton of wiring in your case, but it's possible. This doesn't sound like a small project, but it's one I'd follow.
    My worry for using the fusion brain for HVAC & mission-critical household functions (AC=critical ) is that it doesn't have the reliability and stability testing that a lot of purpose-designed commercial solutions have. There's a reason Crestron costs so much. Then there's windows + custom software to worry about.
    You're trading purpose built hardware+software, and the expertise & testing that goes into that for flexibility and customization. You're the installer, programmer and maintenance - how's your warranty policy? http://www.mp3car.com/vbulletin/imag.../ballchain.gif
    Mar 2006
    Colorado, but Canadian!
    We have just been alerted about a HomeSeer plugin someone made for the FB. Homeseer sotware is meant for Home Automation.
    As for the website, it was down for about 5 minutes yesterday for a server restart but other than that I am not sure.
    1.9in x 2.9in -- 47mm x 73mm
