Results 1 to 10 of 10
Thread: Fusion Brain Reverse Polarity... Fuse blown?
    Jan 2008
    Dartmouth, MA
    I just accidentally hooked up my fusion brain with reverse polarity and now it's not working. Did I blow a fuse? Frankly I'm not too worried about blowing another fuse, so are there just to points I could solder together to bypass the fuse?
    My Nearly Complete Car:
    http://www.mp3car.com/vbulletin/show...ed-car-pc.html
    Micro Control Center... Control Your Car Across the Internet
    http://www.mp3car.com/fusion-brain/1...-internet.html
    Website: (It's a work in progress, really. All my projects have taken me from ever really developing it.)
    http://paulfurtado.com/
    Jan 2008
    Dartmouth, MA
    Nevermind, no fuse blown. Regulator solder joint simply melted off. Fixed.
    Mar 2006
    Colorado, but Canadian!
    Good to see it working.
    As for the fuse, it is thermal. Give it an hour or so and it should work again if it happens. However obviously this can do much much more damage depending on what is connected when it happens.
    1.9in x 2.9in -- 47mm x 73mm
    Jan 2008
    Dartmouth, MA
    Hmm actually it's not working. Only output 0 works. Plugging into any other output makes the blue power LED on the board get brighter. Led for 9 is stuck on, but if you plug a relay into its pins, the light goes out and the relay doesn't click?
    Any idea what the heck is going on? Would there be something simple for me to fix myself?
    Mar 2006
    That weird behaviour suggests you fried it beyond repair.
    Raw Wave
    Nov 2009
    I'd agree - a few shorted transistor eh?
    Big difference between (over) current protection and reverse-polarity protection (albeit fixed with a 20c diode).
    Mar 2006
    Well I have connected the same MCU on a breadboard with reverse polarity as well as +12v directly into VDD (don't ask...) and it worked fine afterwards. However it was a couple seconds at most. So the chip itself has some protection. It sounds like it was on for a while if the solder joint desoldered itself from the heat.
    Raw Wave
    Nov 2009
    It's more a case that the chip has certain tolerance - there isn't any protection.
    Just add a reverse-connected diode after the thermal fuse (IN4004 etc), else full protection (same diode in line, or diode in a series relay's coil circuit if voltage drops are unacceptable).
    Mar 2006
    Right. The chip can take abuse in moderation, that's it. More protection is possible but all designs have tradeoffs.
    Raw Wave
    Nov 2009
    Yep - a 20c tradeoff. But I often reverse polarity protect. Some things are quite easy - that last was an Oatley "smart battery isolator" kit (~$20; 80A) where I simply added a small signal diode on the board in place of an optional resistor for 24V operation. (It protected the chips etc but did not effect the voltage sensing - that was done before the diode.)
    But for 12V etc circuits that drop to 5V, it does surprise me that designers do not include the protection diode. (But that's sometimes an intentional omission.)
  1. Fusion Brain digital output for HVAC.
    By stonestatue in forum General MP3Car Discussion
    Last Post: 05-14-2010, 02:30 AM
  2. Help me troubleshoot my fusion brain
    By djurchicprelude in forum Fusion Brain
    Last Post: 10-11-2009, 03:48 AM
  3. Replies: 17
    Last Post: 01-16-2009, 10:48 AM
  4. How to add a Fusion Brain instance to your configuration file
    By 2k1Toaster in forum FB Documentation and Tutorials
    Last Post: 06-07-2008, 09:42 AM
  5. Polarity of reverse sense wire?
    By drakino in forum Mp3Car Infill G4 - Double Din Car Computer
    Last Post: 06-11-2007, 07:34 AM
