So nobody out there knows how to Activate the Fusion Brain v4 outputs with the press of keyboard keys?
For instance, "Button A" on screen could be momentarily pressed with say the "X" key on a standard keyboard. Etc.
In this MDX software is there a way to bind keyboard hot keys to Output triggers instead of using the click of a button method using a graphical interface? I am trying to do some mobility automation and need a more seamless way to interact with the interface.
Any help would be greatly appreciated,
Ec7
Not exactly. Probably through COM objects. I send commands from RideRunner in this manner.
As far as I can remember, no it is not possible in MDX. I have been working on the new version of the software which does allow this.
1.9in x 2.9in -- 47mm x 73mm
When do you think the new version of the software will be out?
I have a couple other projects on my plate first. It might be a while.
But this is the reason MDX is open source. If you want something, it is possible to add it. I have 1 big contract I need to finish in the next week or two before I can even try to add extras on MDX.
This extra would be greatly appreciated.
