Page 2 of 2 FirstFirst 12
Results 11 to 19 of 19
Thread: Has anyone tried Prosport Gauge senders?
  1. #11
    Jul 2009
    Squamish, BC
    One of my problems is ... your talking way over my level of understanding. I've been sitting on the software side of things for too long and need a simple set of instructions as to what to do. I can see you're trying to be really helpful but I'm still no wiser.
    Best to assume I am still in kindergarten on the hardware front, while on the software side I have a system that can not only read values from the car's CAN bus but also change the setup of the car without touching the normal controls.
  2. #12
    Raw Wave
    Nov 2009
    Ok, your powered sensor puts out 0-5V so that should be okay. (But if you want to decrease the range from 0-5V to 0-4V etc, then the resistive/voltage divider applies.)
    Your temp sender is a resistance. You do not measure resistance per se - you measure the voltage across it & current through it.
    Instead of measuring the current (and voltage), we add a series resistor and merely measure the voltage across it....
    Hence your temp sender needs another resistor placed in series and have a voltage applied....
    Call the added resistor R1.
    Call the temp sender R2.
    Connect them between a voltage Vin.
    You then measure the voltage across the temp sender R2 which is Vout. (See the Wiki voltage divider link as above.)
    You need to calculate the R1 value based on (1) our temp sensor range, (2) the supply voltage Vin, & (3) your desired output voltage range Vout.
    Be aware that Vin needs to be regulated. Hence you might use another regulated source or the FB's 5V etc.
    The problem is that you may want a good voltage range across the temp sender which means a higher voltage supply. This is to make the added resistor as large as possible to reduce the current. (Increased current means more load on the supply (eg, FB) as well as higher resistor wattage ratings.) An alternative is to use a constant current source (typically 2 transistors and a resistor or 2).
    For comparison, many vehicle temp gauges are supplied by an 8V regulated supply.
    Though the above sounds complex, it's just "one bit at a time". I've given you the full byte (in a long-word).
    It is application of one main thing - Ohm's Law (V=IR).
    Also a bit of power ratings (P=VI) and understanding basic circuit theory that series voltages add up (to the supply voltage) and the current flowing through a path is equal through each component (which is really Ohms Law V=IR).
    It's an iterative design. Set your desired temp range (and hence resistance range) and what voltage that should correspond to for your FB.
    You then iterate R1 based in Vin supply voltage and source.....
    ... and then, more Chinese take-away programming tricks....
  3. #13
    Jun 2008
    Georgia, USA
    Here a couple of threads to look at. I was having a hard time understanding voltage dividers also and these were clear enough that even I could understand them.
    The third link is an online voltage divider calculator that will help you find the correct resistor size.
    How do I...
    http://www.mp3car.com/vbulletin/fb-d...-controls.html
    http://www.raltron.com/cust/tools/voltage_divider.asp
    Thanks,
    Dan
  4. #14
    Jul 2009
    Squamish, BC
    Thanks to both of you.
  5. #15
    Jul 2009
    Squamish, BC
    For the temp sensor ...
    Using a 400ohm resistor I will get signal voltage in the range 0.37V - 3.491V
    Connect the 5V out on the FB to one side of the resistor. Connect the other side of the resistor to one of the sensor wires. Connect the other sensor wire to the FB signal. Connect the FB Ground to ground.
    For the pressure sensor...
    Connect battery to 12V wire on the sensor
    Connect signal wire on sensor to FB signal
    Connect the Ground on the sensor to ground
    Connect the Ground on the FB to ground
  6. #16
    Fusion Brain Creator
    Mar 2005
    Quote Originally Posted by Petrie View Post
    close, but connect the "other sensor wire" to ground instead, and the FB signal to the connection between the resistor and sensor.
  7. #17
    Jul 2009
    Squamish, BC
    Connect the other side of the resistor to one of the sensor wires and to FB signal.
    Connect the other sensor wire to ground.
  8. #18
    Constant Bitrate ACCLR8N's Avatar
    Apr 2009
    Davisburg, MI
    FWIW the third FB gound pin doesn't have to be connected to anything.
  9. #19
    Jul 2009
    Squamish, BC
    ^ ok, thanks
  1. LCD Monitor Gauge Cluster
    By warrenb213 in forum mp3Car Innovation Grant - Get One!
    Last Post: 04-19-2011, 11:09 AM
  2. Recommended gauge
    By DracoPCGuy in forum Newbie
    Last Post: 03-31-2008, 10:42 PM
  3. Any Gauge Face Creation Ideas?
    By xhazn in forum Fabrication
    Last Post: 05-18-2005, 08:09 AM
  4. Replies: 22
    Last Post: 03-09-2005, 10:27 AM
  5. Mounting motherboard in WRX gauge pod housing..
    By Giuliano in forum General Hardware Discussion
    Last Post: 07-19-2004, 09:01 AM
