Results 1 to 3 of 3
Thread: FB Password Protected +12V Output
    Sep 2010
    Ok so I am new to the fusion brain concept. Before purchasing i want to know that it will work for what i want.
    Here is the list of what i want to use a FB for:
    -Photo sensitive head lights
    -Password Protected switch that will provide +12V ONLY IF PASSWORD IS CORRECT (Maybe possible to use USB finger print scanner input as password) would prefer this feature to work standalone from pc but not madatory.
    -Monitoring exterior temp, Battery Voltage, Water temp, Oil Temp, Transmission Temp, Exhaust Gas Temp, and Oil Press.
    -Remotely Controlled solenoid (used like a door acuator when remote is pressed will pull for a set time then will release after set time)
    This is all for now..... Maybe if all this works i can expand.....
    Any usefull links to set this up would be appreciated. Also a list of what i would need to do all this would be amazing. Open to any helpful or useful advice as well.
    Low Bitrate UniqelyCommon's Avatar
    Nov 2008
    Teh Internets
    Quote Originally Posted by Dugie33 View Post
    http://store.mp3car.com/Photosensor_p/com-076.htm
    The Fusion Brain needs a computer, though you might want to look at the Interceptor addon
    http://store.mp3car.com/Thermometer_p/com-077.htm
    Battery Voltage,
    Big resistor, or (preferably) http://store.mp3car.com/4_Channel_In..._p/com-118.htm
    same as above, but you might want different physical sensors (consider the temp range)
    and Oil Press.
    150 PSI Air Pressure Sensor but ensure its intended for oil, there are a lot of different rubbers out there (as I'm sure you know )
    http://store.mp3car.com/10pack_of_25..._p/com-085.htm
    Other:
    http://www.mp3car.com/vbulletin/fusi...press-etc.html
    Raw Wave
    Nov 2009
    Try the Arduino Duemilanove etc (ATmega328 CPU).
  1. Laptop HD, password encrypted - break it?
    By kiltjim in forum General Hardware Discussion
    Last Post: 12-03-2004, 11:39 AM
  2. MPJA - MECI ASTEC DC-DC Converter
    By Luc in forum General Hardware Discussion
    Last Post: 11-22-2004, 09:31 PM
  3. Replies: 5
    Last Post: 08-20-2002, 08:29 PM
  4. Will this work? DC-DC 12v input, 12v output 8 amps!
    By nullity in forum Power Supplies
    Last Post: 08-02-2002, 01:49 AM
  5. Finally, 12v @ 5amps !
    By MikeHunt79 in forum Power Supplies
    Last Post: 08-19-2001, 05:47 AM
