Results 1 to 3 of 3
Thread: obdi and fb
    Variable Bitrate nemo1's Avatar
    Jun 2006
    obdi and fb
    Hi,
    I am trying to use sensor data from an obdi car with dashcommand. After reading the threads, I think I need to connect it up like this:
    electrical signals >> FB >> OBDsim >> obdII PIDs >> dashcommand.
    I am running in windows and have set up com0com, run obdsim and a command window appears...then I run dashcommand but it says OBDII interface not found but I was able to run scantools.net and it shows device ready and refresh rates.
    How could I make it work with dashcommand?
    How does obdsim get data from fb? Is it using fbd? Can I use fbd in windows? I downloaded it but could not understand how to exe? Is this approach possible yet?
    Anyone can help? Thanks
    Constant Bitrate ACCLR8N's Avatar
    Apr 2009
    Davisburg, MI
    I don't believe you can run the fusion brain data in dashcommand. Use the MDX software instead. It is Windows based.
    Raw Wave
    justchat_1's Avatar
    Jul 2008
    Boston, Ma or NY,NY
    Quote Originally Posted by nemo1 View Post
    Hi,
    Did you set the correct port and baud rate?
  1. Obdi
    By nemo1 in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 10-15-2010, 04:21 AM
