Page 2 of 4 FirstFirst 1234 LastLast
Results 11 to 20 of 34
Thread: Rpm
  1. #11
    Jun 2008
    Georgia, USA
    Your car most likely has the fuel pump in the tank. Go to an auto parts website like Autozone and lookup your fuel sender. The specs on it will tell you the resistance range. You can do this for oil pressure, water temp, etc. You might even be able to find the number of pulses from your VSS.
    Thanks,
    Dan
  2. #12
    Variable Bitrate nemo1's Avatar
    Jun 2006
    Found this wiring diagram for the Lexus LS400. Should I be tapping the resistor? If yes how should I do it? There probably will be a current flowing thru the resistor already. How could I do a voltage divider?
  3. #13
    Raw Wave
    Nov 2009
    That's the fuel pump circuit - not fuel level.
  4. #14
    Jun 2006
    I've attached the doc of the circuit....I can't seem to find the sensor for fuel level. Only found fuel pressure on the upper right corner of the diagram. Anyone have any ideas what type of sensor a 91 Lexus LS400 uses? Should be resistive type but couldn't find it.
    Another question, I saw the fuel pressure sensor seems to be connected to a solenoid. Does this means it is returning variable frequency signal and not variable electrical signal? I'd need a frequency to voltage converter board right?
  5. #15
    Raw Wave
    Nov 2009
    That's engine control stuff.
    You need the gauge wiring (dash console etc).
    That's assuming you want the fuel (tank) level?
    For engine speed there is the engine speed sensor, left or right dizzy, ignitor, sensor etc.
  6. #16
    Jun 2006
    Yes I need the fuel (tank level).
  7. #17
    Raw Wave
    Nov 2009
    Just to allay some concerns. (Yes - "The Man" is concerned - probably just like others including myself.)
    With regard to the fuel sender....
    FORGET EVERYTHING to do with the diagram you have posted etc.
    The resistor is to reduce fuel pump current at certain times.
    The fuel pressure switch is a safety etc sensor.
    18k sounds VERY wrong for a fuel sender.
    Chances are your fuel sender will be from near 0R (zero Ohms) empty to around 100R full. (For Lexus I have read ranges like (roughly) from 0R to 5R, 0-72R, 0-140R.)
    Your sender voltage may vary if the fuel gauge has a bi-metal voltage regulator. These pulse on/off to provide an average voltage (usually ~8V).
    If so, you need to integrate the signal (ie, an RC filter, I wouldn't use FB or uPC etc averaging). Maybe a 3-10 second filter is sufficient. Else use an analog regulator.
    (If you disconnect the sender, no filtering (other than noise) is required; eg - use it with a 47R resistor.)
    Stay away from anything on that diagram that you posted. (Except for the ignition/RPM signals).
    That diagram has NOTHING to do with the fuel gauge.
    So too the replies if referring to that diagram... (including resistance changes with engine running or not).
    With thanks to "The Man"... (u know who you are)
  8. #18
    Jun 2008
    Georgia, USA
    Looking at Autozone's website, it appears that the fuel level sender reads 240ohm empty and 33ohm full.
    Thanks,
    Dan
  9. #19
    Jun 2006
    Quote Originally Posted by OldSpark View Post
    Where can I get the signal that you mentioned from?
  10. #20
    Raw Wave
    Nov 2009
    From the fuel gauge. EG - the fuel tank sender or the dash.
  1. If RPM, then power my device
    By WhipClash in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 11-19-2009, 08:39 AM
  2. Rpm Pid
    By mohfa in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 11-16-2007, 11:53 PM
  3. Performance 10k RPM tach with shift lights and backlight
    By pcgamer4life in forum Classified Archive
    Last Post: 01-16-2006, 11:08 AM
  4. OBDII RPM output?
    By TurboNova in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 09-09-2005, 02:55 PM
  5. Change volume with Engine RPM
    By FunkDaMonkMan in forum Software & Software Development
    Last Post: 01-01-2005, 11:27 AM
