Page 14 of 26 FirstFirst ... 456789101112131415161718192021222324 ... LastLast
Results 131 to 140 of 260
Thread: ** NEW Fusion Brain Version 6, Pre-Order NOW **
  1. #131
    Mar 2006
    Colorado, but Canadian!
    I have had way too many clear plastic bags with "we're sorry" printed on them and then remnants of a box inside it that vaguely resembles the packaging of something I ordered online from USPS to make me want to use them for time sensitive things. When it is my choice, I go FedEx.
    1.9in x 2.9in -- 47mm x 73mm
  2. #132
    Mar 2006
    Quote Originally Posted by dscustoms View Post
    Really? Do they just not tell you? I'm shocked that fedex would blatantly state they had it on the truck but wouldn't deliver. "Package not due for delivery" Twice!
    Well FedEx tracks every item closely. I have had many things delivered that according to USPS were still waiting to be collected. Likewise things that USPS said were delivered, but I hadn't received. So even if they wanted to tell you it was there and they weren't delivering it, they wouldn't.
  3. #133
    Low Bitrate UniqelyCommon's Avatar
    Nov 2008
    Teh Internets
    Ah, government efficiency
  4. #134
    Feb 2002
    Not .gov, for a long time. Technically. So to each their own, I ship everyday, 6-12 packages, priority mail flat rate boxes, envelopes etc... No problems in a lot of months!
    Back on topic. You said I can see analog inputs with fuse GL... How? I'm not experienced with software, but I can figure it out if I have basic commands to start with. Don't you have a list of what I can use in the XML file somewhere?
    Old School MP3CAR.com member!
  5. #135
    Mar 2006
    Did you download the newest version? When you open it up, you should see a label on the bottom that shows 00.000 or something like that. That is reading an input. If you look in the User configuration xml file it is (currently) the last FuseGL item.
  6. #136
    Feb 2002
    mine doesn't have that. last item is the output I made.
  7. #137
    Mar 2006
    The 19-05-2011 version?
    Here is the code anyways:
    Code:
      <User_Object type="FuseGL_Object">
        <setting type="string" name="Analogue Input 0.0 Display Label" />
        <image location="internal" path="FuseGL.Configurator.Configurator_IMG_Resources.BaseButton" />
        <text text="Unknown State" />
        <setting type="bool" mouse_cursor_to_hand_on_hover="true" />
        <size width="200" height="33" />
        <location x="500" y="500" z="0" alignment="center" />
        <events>
          <startup action="FuseGL.ExecuteCode" inputArgs="UpdateLabelText.cs;FuseGL_TextManipulation.InternalFlyCompile_UpdateLabelText;ChangeButtonTextOnAnalogueInputPersistant;{FB.AnalogueInput(0.1)};{this.text};00.0000;" outputTo="this.text.text" />
        </events>
      </User_Object>
  8. #138
    Feb 2002
    Nope, just reinstalled it too.. That code isn't in the one in the first post. Also, adding that code to the xml file causes the program to not open? Strange.
  9. #139
    Feb 2002
    Aha, check your DL link. Text says 5-19 but link is to 4-19 b something. i'll try and find the real file.
  10. #140
    Mar 2006
    If it doesn't open then check the trace that is output. Post that.
    And that tells me there is a good chance you don't have the version from yesterday.
  1. Fusion Brain V4 Digital Inputs
    By malcom2073 in forum Fusion Brain
    Last Post: 02-14-2009, 12:16 PM
  2. Replies: 41
    Last Post: 01-11-2009, 03:46 PM
  3. Fusion Brain and iBus
    By nemo1 in forum Fusion Brain
    Last Post: 12-15-2008, 11:05 AM
  4. Vista won't see the Fusion Brain
    By Ineffigy in forum Fusion Brain
    Last Post: 11-26-2008, 07:39 AM
  5. Fusion Brain and its uses!
    By HiJackZX1 in forum Fusion Brain
    Last Post: 06-08-2008, 07:41 PM
Tags for this Thread
