Got my shipping notice for 2 v6's. Looking forward to having 60 channels of fireworks launching madness vs the current 16.
Gonna need a slightly larger box for all those relays![]()
If it shows it opening and then closing, look in the folder and you should see "FuseGL_Trace.txt". Post that. If that is not there, then program is not actually opening. The first thing it does is try to write that file, or just create it. If it was opening, there would be a blank 0 byte file with that name at a minimum.
I will try to get some sort of version identifier over the weekend.
1.9in x 2.9in -- 47mm x 73mm
Yea there's no file created. I'll keep trying it on different PC's
Love
I think I figured it out. My XP Virtual Machine barfed too. Try it on a machine that does not require 32x32 pixel icons. So Vista or Win7 (they use up to 256x256 pixel icons). The low level log says it failed loading icons, so that's all I got right now. I am looking into where I even use a true icon and then I'll make it 32x32...
Alright, I fixed it for legacy systems. I am uploading a new copy now.
Yaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaay! It worked. Took a second to load so I got scared but then it popped up!
Love
Fusion Control Center is now coming up, but the Window is black and the Buttons are white with no readable text.
The Buttons do appear to work. The LED on Digital#10 is On, Off, Toggle with Buttons1-2-3.
Not clear what to expect from Button4.
Running a P4 2.53GH with 1GB and a RADEON9200SE on WindowsXP.
It's taking almost one minute to load.
lol a 9200? Ok that doesn't support OpenGL 2.0, it is wonder anything works at all!
Worse news is that upon installing on the Mini-Itx board running Windows 7, I have discovered that the Intel 945GM chipset also doesn't support OpenGL 2.0. So "Huston", I've got a problem.
