Page 19 of 26 FirstFirst ... 91011121314151617181920212223242526 LastLast
Results 181 to 190 of 260
Thread: ** NEW Fusion Brain Version 6, Pre-Order NOW **
  1. #181
    Mo' Programming Mo' Problems
    Sonicxtacy02's Avatar
    Woodbridge, VA
    Blog Entries
    55
    well that solves part of the problem. In the other thread i read aa? and AA? as the same return. The next problem is the return i get from aa? vs AA?
    aa?
    Code:
    aa?
    aa?
    0.8967v;0.451v;0.483v;0.451v;0.483v;0.161v;0.483v;0.451v;0.483v;0.741v;0.1354v;0
    .483v;0.516v;0.483v;0.0v;
    AA?
    Code:
    AA?
    AA?
    279
    AA?
    2;16
    AA?
    27;16
    AA?
    27;15
    AA?
    27;13
    AA?
    27;4
    AA?
    279;15
    AA?
    27;15
    AA?
    27;16
    AA?
    27;22
    AA?
    27;42
    AA?
    27;15
    AA?
    27;16
    AA?
    27;16
    AA?
    27;0;
    I don't understand the format of AA? First, it has returns, and second, it doesnt appear to have all 16 analog input values, and it appears a few are duplicated (ex. 279). I only have one temp sensor connected to port 0
    Live mp3Car Facebook Chat
  2. #182
    Low Bitrate UniqelyCommon's Avatar
    Nov 2008
    Teh Internets
    Quote Originally Posted by sonicxtacy02 View Post
    i don't understand the format of aa?
    I don't think its behaving as 2k1Toaster intended, on mine I'm seeing
    Code:
    >AA?
    AA?
    286AA?
    AA?;0;0;0;0;0;0;0;0;0;0;0;0;0;0;
    and I think this is intended:
    Code:
    >AA?
    AA?
    286;0;0;0;0;0;0;0;0;0;0;0;0;0;0;0;
    Here are some log files:
    Attached Files Attached Files
  3. #183
    Mar 2006
    Colorado, but Canadian!
    The VCP port could very well have problems. It was meant to be used for testing and basic control, not the main source of access. I will look into it though, but I will be working on my software first.
    1.9in x 2.9in -- 47mm x 73mm
  4. #184
    Mar 2006
    Quote Originally Posted by waltersaegir View Post
    Worse news is that upon installing on the Mini-Itx board running Windows 7, I have discovered that the Intel 945GM chipset also doesn't support OpenGL 2.0. So "Huston", I've got a problem.
    Ok, I have a... well not "working", but workable test program for you to try: http://fusioncontrolcentre.com/FBV6/...2011-06-11.zip
    It wont be legible or drawn to scale. Infact it will probably look horrid. But you *should* see something more than just boxes. Let me know if that works for you. If so, then it is just some complex math that needs to be done and it should be fixed.
    The above is to be tested by anyone with non OpenGL 2.0 compatible hardware.
  5. #185
    Nov 2008
    Teh Internets
    Sounds like the best prioritizing I believe "aa?" is working as expected so, while there will be a little bit lost in translation/calculation, I would imagine it should work for now.
  6. #186
    Mar 2006
    I fixed the link in post #184. It was missing the " "/"%20"
  7. #187
    May 2006
    Quote Originally Posted by 2k1Toaster View Post
    Yep, I can see the boxes and the font looks kinda like Arabic.
    Also, in the upper left of the screen "FUS" is readable and appears to have the rotating small blue icon circle right above and to the left.
    Interesting to note that the 'X' and '-" Window Controls appear (and are functional) on the XP Desktop machine and do not appear on the Windows 7 Mini-itx board.
  8. #188
    Mar 2006
    The window control bar and title bar appears? That's odd. Do you have a screenshot of that?
  9. #189
    May 2006
    Screen Shot of FuseGL Alpha
    The Screen Shot from the XP Desktop machine is attached.
  10. #190
    Mar 2006
    oh ok. So the windows controls don't appear. Those are all custom textures, that act like a title bar and minimize/max/close. The real ones are hidden and that's the way it should be.
    Ok, now I am trying to figure out the math to make these gigantic non-linearly sized images now appear normal...
  1. Fusion Brain V4 Digital Inputs
    By malcom2073 in forum Fusion Brain
    Last Post: 02-14-2009, 12:16 PM
  2. Replies: 41
    Last Post: 01-11-2009, 03:46 PM
  3. Fusion Brain and iBus
    By nemo1 in forum Fusion Brain
    Last Post: 12-15-2008, 11:05 AM
  4. Vista won't see the Fusion Brain
    By Ineffigy in forum Fusion Brain
    Last Post: 11-26-2008, 07:39 AM
  5. Fusion Brain and its uses!
    By HiJackZX1 in forum Fusion Brain
    Last Post: 06-08-2008, 07:41 PM
Tags for this Thread
