Page 20 of 26 FirstFirst ... 1011121314151617181920212223242526 LastLast
Results 191 to 200 of 260
Thread: ** NEW Fusion Brain Version 6, Pre-Order NOW **
  1. #191
    Mar 2006
    Colorado, but Canadian!
    Ok now try this: http://fusioncontrolcentre.com/FBV6/...011-06-11b.zip
    I think this should work... Replace the exe with the one in the zip.
    1.9in x 2.9in -- 47mm x 73mm
  2. #192
    May 2006
    FuseGL Alpha Font Fix
    Better Font!
  3. #193
    Jan 2008
    Dartmouth, MA
    Is there a current full list of supported serial commands and what they do?
    I've been digging through this thread trying to find them all.
    My Nearly Complete Car:
    http://www.mp3car.com/vbulletin/show...ed-car-pc.html
    Micro Control Center... Control Your Car Across the Internet
    http://www.mp3car.com/fusion-brain/1...-internet.html
    Website: (It's a work in progress, really. All my projects have taken me from ever really developing it.)
    http://paulfurtado.com/
  4. #194
    Jan 2008
    Dartmouth, MA
    Also, using DD:XX:1 turns on a port, but the port just blinks extremely quickly. This happens with USB power and a 12 volt power supply.
  5. #195
    Mar 2006
    Make sure you have the latest firmware. What does it say when you do "*IDN?"
    Also D:XX:1 turns on an output to 1/255 PWM. D:XX:255 turns an output fully on.
  6. #196
    Jan 2008
    Dartmouth, MA
    Quote Originally Posted by 2k1Toaster View Post
    Code:
    Fusion Control Centre
    www.FusionControlCentre.com
    SN: -1124040704
    D:XX:Y doesn't work for me with anything that doesn't have a 1 as its first digit for Y so I'm assuming I have old firmware.
  7. #197
    Jan 2008
    Dartmouth, MA
    And I just looked through this thread with firmware as my search and it came up. I'll update it when I get home from work. There needs to be a "getting started" page or something with the basics so people like me don't ask "dumb" questions.
  8. #198
    Jan 2008
    Dartmouth, MA
    Firmware fixed it. Working great now. I've never heard my relays so quiet.
    Still interested in knowing the full list of commands. So far I know of:
    *IDN?, DD:XX:Y, a? aa, and AA.
    Most importantly:
    Is there anything that gets the state of an output?
    Though that of course can be worked around.
  9. #199
    Low Bitrate UniqelyCommon's Avatar
    Nov 2008
    Look behind you.
    What I've seen (and tested):
    Code:
    *IDN?
    DD:XX:Y
    a?
    aa?
    A?
    AA?
    All are different commands.
    Quote Originally Posted by PaulF View Post
    I'd support a
    Code:
    DD?
    command. That would be useful in the event of the Fusion Brain being connected to constant power but the computer restarting, etc.
    Also maybe
    Code:
    DD:XX?
    for a single?
    but the FusionBrain .NET software is just a tad higher on the priority list
  10. #200
    May 2006
    "but the FusionBrain .NET software is just a tad higher on the priority list": so do I understand from this that currently FusionBrain Version 6 and Fusion Control Centre MDX cannot be used together?
  1. Fusion Brain V4 Digital Inputs
    By malcom2073 in forum Fusion Brain
    Last Post: 02-14-2009, 11:16 AM
  2. Replies: 41
    Last Post: 01-11-2009, 02:46 PM
  3. Fusion Brain and iBus
    By nemo1 in forum Fusion Brain
    Last Post: 12-15-2008, 10:05 AM
  4. Vista won't see the Fusion Brain
    By Ineffigy in forum Fusion Brain
    Last Post: 11-26-2008, 06:39 AM
  5. Fusion Brain and its uses!
    By HiJackZX1 in forum Fusion Brain
    Last Post: 06-08-2008, 06:41 PM
Tags for this Thread
