Page 21 of 26 FirstFirst ... 11121314151617181920212223242526 LastLast
Results 201 to 210 of 260
Thread: ** NEW Fusion Brain Version 6, Pre-Order NOW **
  1. #201
    Low Bitrate UniqelyCommon's Avatar
    Nov 2008
    Look behind you.
    I'm just another enthusiast, the only thing that can mean for sure is that there's software in development
    I've moved over to Ubuntu and don't use my Windows partition enough to download and try out any .NET-based software (which the existing MDX is, too)
    (Just saying that there's likely more people to benefit from the time spent software writing than ROM-based COM command creation coding.)
  2. #202
    May 2006
    Yes I understand.
    I was looking for clarification from 2k1Toaster.
    Can FusionBrain Version 6 and Fusion Control Centre MDX cannot be used together?
  3. #203
    Mo' Programming Mo' Problems
    Sonicxtacy02's Avatar
    Woodbridge, VA
    Blog Entries
    43
    Quote Originally Posted by waltersaegir View Post
    Yes I understand.
    They definitely cant now. Based on the fact he's building a new app on a new framework, my guess is it wont ever be.
    Live mp3Car Facebook Chat
  4. #204
    Variable Bitrate rEegLer's Avatar
    Jul 2008
    Mechanicsburg, PA
    I'm assuming with this new version that there is no way to only be powered by the DC plug? I relied on that function with the V4 because my motherboard supplies power to the USB ports during sleep (can't change it).
    Love
  5. #205
    Feb 2002
    Redding, California, United States
    If you leave the power plug connected when the USB line is removed, the FB remains in its last state.
    Old School MP3CAR.com member!
  6. #206
    Mar 2006
    Colorado, but Canadian!
    "but the FusionBrain .NET software is just a tad higher on the priority list": so do I understand from this that currently FusionBrain Version 6 and Fusion Control Centre MDX cannot be used together?
    Correct.
    Yes I understand.
    No. FuseGL is the future as of now.
    Quote Originally Posted by Sonicxtacy02 View Post
    Correct. During FBv6 development last November while I had a bunch of test leads with bare wires everywhere I shorted my laptop's supply with test probes destroying it completely. In doing so I lost my partition that could build MDX. I still have all the source (and it is available online too as it is open source) but I have not bothered installing the 4Gb+ of dev files from Microsoft for DirectX to get it to compile. So I currently have no way of building a new version to add support anyways. FuseGL has been in development off and on for over a year, so it was time to just cut the cord and move on.
    Quote Originally Posted by rEegLer View Post
    Quote Originally Posted by dscustoms View Post
    It can be powered from either source (DC or USB) but no longer requires a jumper change. You can plug it into one or the other or both and it will automatically select which source to use and power the system. You can plug and uplug them at any time. For the DC Jack to work, the input voltage should be something around 5.3v or more. Anything below that and there is no guarantee it wont pull from the USB port. You can power it with anything above 3.6v though with no USB port. But as soon as you plug in USB (~4.6v to 5.1v) it will use that.
    1.9in x 2.9in -- 47mm x 73mm
  7. #207
    May 2006
    Yikes!
    Not sure now where to look for documentation on how to use.
  8. #208
    Mar 2006
    Yikes!
    Currently the documentation for the FBv6 is just what is found on the forums. There is a full manual coming at some point.
    If you have a question ask. I am usually here pretty quick to answer. If not then email. I try to keep up on the forums when I can, and it makes a good knowledge depository.
  9. #209
    May 2006
    The first question that comes to mind is how to interface software like java script for example.
    Using the temperature/heat sensor that came with the board, what code would read the sensor?
  10. #210
    Mar 2006
    Why interface javascript? If you want different software to control it, then that's on you.
    To use FuseGL and read a sensor, you would open it, press F10, then follow the prompts to add a label to display an analogue voltage. Done.
  1. Fusion Brain V4 Digital Inputs
    By malcom2073 in forum Fusion Brain
    Last Post: 02-14-2009, 11:16 AM
  2. Replies: 41
    Last Post: 01-11-2009, 02:46 PM
  3. Fusion Brain and iBus
    By nemo1 in forum Fusion Brain
    Last Post: 12-15-2008, 10:05 AM
  4. Vista won't see the Fusion Brain
    By Ineffigy in forum Fusion Brain
    Last Post: 11-26-2008, 06:39 AM
  5. Fusion Brain and its uses!
    By HiJackZX1 in forum Fusion Brain
    Last Post: 06-08-2008, 06:41 PM
Tags for this Thread
