Page 23 of 26 FirstFirst ... 1314151617181920212223242526 LastLast
Results 221 to 230 of 260
Thread: ** NEW Fusion Brain Version 6, Pre-Order NOW **
  1. #221
    Variable Bitrate rEegLer's Avatar
    Jul 2008
    Mechanicsburg, PA
    Other than the log, no. I saw the update file grow as it was downloading but after the update everything looks fine.
    Love
  2. #222
    Mar 2006
    Colorado, but Canadian!
    Quote Originally Posted by rEegLer View Post
    Cool beans.
    I experimented with this by doing things on external networks (like using my phone vs. home network vs. server network) and it all worked, but it is good to know it works in practice. It was a shot in the dark coding experiment to have it update itself with minimal hassle.
    Thanks for the feedback.
    1.9in x 2.9in -- 47mm x 73mm
  3. #223
    May 2006
    UpDate Worked Prob w/ButtonAdd B4&A Update
    The update worked fine, *but* I am experiencing a problem with Menu-ButtonAdd after I draw the Button it asks for a FB number 9876543210 and I enter '0'. Then FuseGL dies.
    This happened with the previous version (1.1.0.105) as well as the version after the AutoUpdated version (1.1.0.159).
    This is on the Mini-ITX with Windows 7.
    I've attached files for Update, Trace, and Screen Shot.
    Attached Files Attached Files
  4. #224
    Mar 2006
    I think I reproduced it.
    Use the keyboard (hardware not OSK) in the interim.
  5. #225
    Jul 2008
    Mechanicsburg, PA
    I forgot to mention this sooner but it is not letting me add a Variable label. I get to the point where I click the "Variable; Display String Value" and after I click it, nothing happens, can't click anything. I have to double tab space bar to get back to the add menu.
    Love
  6. #226
    Mar 2006
    See above post:** NEW Fusion Brain Version 6, Pre-Order NOW **
  7. #227
    Jul 2008
    Mechanicsburg, PA
    Sorry! I never saw that post.
    Love
  8. #228
    Jul 2008
    Mechanicsburg, PA
    Can I edit the persistantvariables.xml file to add variables? Or can I manually add the variables through the config file? I just don't know the formats for anything until I see an example.
    Love
  9. #229
    Mar 2006
    You can manually enter variables now, but it won't be necessary soon. I am working on getting variable editing done in the GUI.
    You add them to UserConfig.xml and its format is:
    Code:
      <Persistant_Variables>
        <variable type="bool" first_value="true" name="persistant_boolean" />
        <variable type="int" first_value="0" name="persistant_incrementer" />
      </Persistant_Variables>
    That subnode is under the root node. Same level as Startup_Events and User_Object.
  10. #230
    Jul 2011
    I'm having the same output problem, I can only get 1 on at a time
    Any new updates with FuseGL? I played around with it a little bit but only to the point of adding inputs and outputs and not figuring out why I could only have one output switched at a time. I really want to switch my system over to the V6 but I can't until it can do variables and logic.
    I'm new to FuseGL & the Fusion Brain. I've been working on the config file and have been unable to get more than 1 digital output on at a time. Each time I click a different toggle button the previous output port turns off and the new one turns on. I also would like to be able to turn on multiple outputs with 1 button. Can anyone help me with this, maybe with a sample of the proper code to perform these functions.
  1. Fusion Brain V4 Digital Inputs
    By malcom2073 in forum Fusion Brain
    Last Post: 02-14-2009, 12:16 PM
  2. Replies: 41
    Last Post: 01-11-2009, 03:46 PM
  3. Fusion Brain and iBus
    By nemo1 in forum Fusion Brain
    Last Post: 12-15-2008, 11:05 AM
  4. Vista won't see the Fusion Brain
    By Ineffigy in forum Fusion Brain
    Last Post: 11-26-2008, 07:39 AM
  5. Fusion Brain and its uses!
    By HiJackZX1 in forum Fusion Brain
    Last Post: 06-08-2008, 07:41 PM
Tags for this Thread
