Page 6 of 26 FirstFirst 12345678910111213141516 ... LastLast
Results 51 to 60 of 260
Thread: ** NEW Fusion Brain Version 6, Pre-Order NOW **
  1. #51
    Mar 2006
    Colorado, but Canadian!
    It lives!!!
    1.9in x 2.9in -- 47mm x 73mm
  2. #52
    Low Bitrate UniqelyCommon's Avatar
    Nov 2008
    Look behind you.
    "Its alive, its alive!!"
  3. #53
    Sep 2007
    Export, PA
    you know i'll grab at least one of these as soon as they're done man! just one of these would most likely be enough for my car, lol...
    Planning: [|||||||||-] 90%
    Purchased: [|||||||||/] 99%
    Installation: [|||||||||-] 90% (when is anyone's project ever REALLY done...)
  4. #54
    Sep 2007
    Export, PA
    wait i just thought about something....... sensors will now be 3.3v? does this mean i cant monitor my 0-5V sensors that came with my car??? That's going to be a pain if I have to use a voltage divider just to read O2, throttle position, MAP, TIP, etc...
  5. #55
    Mar 2006
    You can use those sensors. Easiest is voltage divide them.
    However, they may not be 5v sensors. They may be 5v because they are being supplied with 5v, but are actually resistive. So if you connect their supply to 3.3v, then they magically become 3.3v sensors. Now this obviously wont work with everything, but it is a possibility. The easiest method is just divide them.
    I may even make some easy to use voltage divider boards that only do this if demand is high enough.
  6. #56
    Constant Bitrate ACCLR8N's Avatar
    Apr 2009
    Davisburg, MI
    Quote Originally Posted by sxtnitehawk View Post
    Warning: They are like peanuts.
  7. #57
    Sep 2007
    Export, PA
    Quote Originally Posted by 2k1Toaster View Post
    unfortunately i cant change the supply voltage, and none are resistive..... the sensors already in the car have their own 5v supply and i just read the analog return off the sensors...
    also.... changing to 3.3v doesnt increase accuracy...because all you did was change the range... to increase accuracy you will have to bump up the number of readable steps. you now have i believe 1023 right? increase that and you'll increase the accuracy because you'll take the same range and split it up into even smaller measurable segments... for instance, with a 5v range, if you take your .0049v accuracy, double the steps, now you have accuracy to within .00245v...
    Quote Originally Posted by ACCLR8N View Post
    huh?
  8. #58
    Mar 2006
    Then use dividers
    There is a lot more behind the scenes to increase accuracy. A different ADC (same topology, different tech), more stable power regulation, and more.
    huh?
    Addictive
  9. #59
    Mar 2006
    Interface 1 is working.
    Alright, it is up and running. I can control relays and read back sensors.
    This version will have something special for you guys, a serial interface. I am currently trying to get both interfaces to coexist and be happy. But as of right now, it is controllable with your favourite terminal program. This also means it should work on any OS, and be usable in a couple seconds from the command line, something that has been requested a lot (or at least was back in the day).
  10. #60
    May 2006
    Yea
    Appreciate the update!
  1. Fusion Brain V4 Digital Inputs
    By malcom2073 in forum Fusion Brain
    Last Post: 02-14-2009, 11:16 AM
  2. Replies: 41
    Last Post: 01-11-2009, 02:46 PM
  3. Fusion Brain and iBus
    By nemo1 in forum Fusion Brain
    Last Post: 12-15-2008, 10:05 AM
  4. Vista won't see the Fusion Brain
    By Ineffigy in forum Fusion Brain
    Last Post: 11-26-2008, 06:39 AM
  5. Fusion Brain and its uses!
    By HiJackZX1 in forum Fusion Brain
    Last Post: 06-08-2008, 06:41 PM
Tags for this Thread
