Page 8 of 26 FirstFirst 123456789101112131415161718 ... LastLast
Results 71 to 80 of 260
Thread: ** NEW Fusion Brain Version 6, Pre-Order NOW **
  1. #71
    Aug 2006
    Central PA
    I'm assuming since this version is more accurate we'll be able to have longer cables? My current project will require either a 100' cable or I'll need to mount a laptop (and the brain) in a weatherproof box outdoors. It'd be nice if the 100' cable was possible.. somehow.
    Anyway, hopefully I'll be able to pick up one of the preorders before they ship. Wait until next week *wink*.
  2. #72
    Low Bitrate UniqelyCommon's Avatar
    Nov 2008
    Look behind you.
    *cough* Another good reason for Tx/Rx pins (XBee/RF) *cough*
  3. #73
    Feb 2002
    Redding, California, United States
    Got mine today, It lights up, and I'm excited! No documentation though, not even a hint. Oh, and the old drivers don't work either... The little LEDs light up so bright that you can't actually see when you look at them.
    I'll send an email as well as this post.
    Thanks!
    Dave
    Old School MP3CAR.com member!
  4. #74
    Mar 2006
    Colorado, but Canadian!
    Quote Originally Posted by dscustoms View Post
    Thanks!
    Dave
    Oh you wanted it to work? That'll cost extra!
    And all existing documentation was shipped with them. i.e. none.
    I'll upload the goods soon so you can start playing.
    ---------- Post added at 07:49 PM ---------- Previous post was at 07:23 PM ----------
    Drivers: http://www.fusioncontrolcentre.com/FBV6/FBv6%20INF.zip
    1.9in x 2.9in -- 47mm x 73mm
  5. #75
    Feb 2002
    Ok, I have drivers and they loaded! Now what
  6. #76
    Mar 2006
    Easiest quick and dirty test method is to use hyperterminal to talk to the com port.
    You can do things like:
    "D:NN:S" where NN is the two digit digital output 0-index based channel, and S is 0 or 1 for on or off. So "D:00:1" is turn on channel 0. and "D:23:0" is turn off channel 23.
    "A?" and "a?" report back the analogue values
    "*IDN?" reports back its info, the serial numbers are scrambled for the betas
  7. #77
    Feb 2002
    Nevermind! I didn't have it plugged into a power supply, it seemed to be working from just USB. Hooked it up to +12 and it's talking back!!
    Time to see if it works, please keep us updated when MDX works with this
  8. #78
    Mar 2006
    It's not part of win7 or vista. However you can use the XP version found here: http://digitizor.com/2009/08/29/how-...indows-7-free/
    Actually none of the connection settings matter except the port number. You need to change it to the port specified in Device Manager, then click connect.
    Also if you unplug the device without disconnecting you will brick hyperterminal. You then need to disconnect and close and unplug the device. Then open hyperterminal try and connect, it will fail, then close, then plug in the device, then try to reconnect again. Make sure the port stays the same.
    This is a stupid hyperterminal problem. You can use any com port software though.
  9. #79
    Jan 2008
    Dartmouth, MA
    Quote Originally Posted by scotty562 View Post
    Check out this link: http://www.google.com/products/catal...d=0CDwQ8wIwAg#
    It uses a converter to shoot the USB across up to 200 feet of cat5 to the converter on the other side. I used to use a device similar to this at work to keep computers out of a warehouse freezer, albeit the device we were using had a 4 port hub built in.
    2k1,
    Will it need any special drivers in linux or will it just identify itself as one of the USB-Serial devices the kernel has "built-in drivers" for?
    My Nearly Complete Car:
    http://www.mp3car.com/vbulletin/show...ed-car-pc.html
    Micro Control Center... Control Your Car Across the Internet
    http://www.mp3car.com/fusion-brain/1...-internet.html
    Website: (It's a work in progress, really. All my projects have taken me from ever really developing it.)
    http://paulfurtado.com/
  10. #80
    Feb 2002
    I edited my post. Now I'm wrong again. I thought it didn't work without a power supply connected, but now it's talking with only USB connected. What are the power supply requirement specs on this?
  1. Fusion Brain V4 Digital Inputs
    By malcom2073 in forum Fusion Brain
    Last Post: 02-14-2009, 11:16 AM
  2. Replies: 41
    Last Post: 01-11-2009, 02:46 PM
  3. Fusion Brain and iBus
    By nemo1 in forum Fusion Brain
    Last Post: 12-15-2008, 10:05 AM
  4. Vista won't see the Fusion Brain
    By Ineffigy in forum Fusion Brain
    Last Post: 11-26-2008, 06:39 AM
  5. Fusion Brain and its uses!
    By HiJackZX1 in forum Fusion Brain
    Last Post: 06-08-2008, 06:41 PM
Tags for this Thread
