Anything between 4.5v and 28v on the input and everything will work. Lower is better for LED heat on the betas. Won't be an issue later
---------- Post added at 11:04 PM ---------- Previous post was at 11:02 PM ----------
You should be able to just point virtual COM drivers at it and be done with it in any OS.
It also supports the same mode as before which is a generic bulk USB device. Throughput is 1Mbps in bulk mode.
