Page 9 of 26 FirstFirst 12345678910111213141516171819 ... LastLast
Results 81 to 90 of 260
Thread: ** NEW Fusion Brain Version 6, Pre-Order NOW **
  1. #81
    Mar 2006
    Colorado, but Canadian!
    Quote Originally Posted by dscustoms View Post
    I edited my post. Now I'm wrong again. I thought it didn't work without a power supply connected, but now it's talking with only USB connected. What are the power supply requirement specs on this?
    Anything between 4.5v and 28v on the input and everything will work. Lower is better for LED heat on the betas. Won't be an issue later
    ---------- Post added at 11:04 PM ---------- Previous post was at 11:02 PM ----------
    Quote Originally Posted by PaulF View Post
    2k1,
    Will it need any special drivers in linux or will it just identify itself as one of the USB-Serial devices the kernel has "built-in drivers" for?
    You should be able to just point virtual COM drivers at it and be done with it in any OS.
    It also supports the same mode as before which is a generic bulk USB device. Throughput is 1Mbps in bulk mode.
    1.9in x 2.9in -- 47mm x 73mm
  2. #82
    Mo' Programming Mo' Problems
    Sonicxtacy02's Avatar
    Woodbridge, VA
    Blog Entries
    55
    can anyone here talk to the v6 on a 64bit system? I got the driver to install and i see "Fusion Brain Version 6 RS232 Interface (COM2)" in device manager, but using the commands like "A?" and others mentioned above dont seem to do anything. I'm using Putty to communicate.
    Live mp3Car Facebook Chat
  3. #83
    Mar 2006
    Quote Originally Posted by Sonicxtacy02 View Post
    My dev system is Win7x64
    Are you on windows?
  4. #84
    Low Bitrate UniqelyCommon's Avatar
    Nov 2008
    Teh Internets
    Which end-of-line character(s) are you using? Do those even matter? :/
    (What's the max supported baud rate, out of curiosity? )
    Last edited by UniqelyCommon; 03-08-2011 at 02:41 PM. Reason: EOL may not matter...
  5. #85
    Mar 2006
    It requires '\n' to start processing. '\r' is ignored. So it should work on any OS.
    The quickest way to make sure it is working is to send it "*IDN?" and that should return back information always. If not, then something else is wrong there.
    As for max baud rate, it doesn't have a limit. The theoretical maximum is 1Mbps as per USB CDC specifications. All UART activity through USB disregards all baud rate information. It is up to the device (i.e. The Fusion Brain) to buffer the incoming packets, and send them out of an actual UART pin at the correct speed. Then signal the host "hey I'm done give me some more". The FB doesn't actually send it out, it just processes it internally. So it actually receives the info, stores it, and immediately says "gimme more". So it can run at the maximum speed USB allows. The FB ignores all baud rate settings.
  6. #86
    Woodbridge, VA
    Blog Entries
    55
    Quote Originally Posted by 2k1Toaster View Post
    Are you on windows?
    Yes in windows, dsatx is powered by 12v. But i'm not getting any returns at all. I also notice when i first installed the FB there were 3 missing drivers, the RS232, the WINUSB interface, and something like "Uber speed mode" or something to that affect. Now that the drivers are installed i only have the RS232 and WinUSBs shown. Is this normal?
  7. #87
    Mar 2006
    Use hyperterminal and we can eliminate a problem with putty that way.
    You installed both drivers? If in windows, I believe you should just see it listed under the Ports device manager tab.
    Can you post a screenshot of Devicemanager?
  8. #88
    Woodbridge, VA
    Blog Entries
    55
    screenshot attached. Gonna download ht now and try that.
  9. #89
    Mar 2006
    Ok, seems good. There was a previous version of the driver that put it alongside the other interface, but then Windows would freeze when you tried to open up a port. Apparently Windows requires a COM port to be listed in the Ports (COM & LTP1) Section only... But that isn't the issue here, so try hyperterminal.
  10. #90
    Woodbridge, VA
    Blog Entries
    55
    Tried hyperterminal and its the same thing. I should clarify, when i say it doesnt return anything what i really mean is it doesnt appear to ever connect. The bottom bar of HT says connected, but when i type *IDN and hit enter nothing happens.
  1. Fusion Brain V4 Digital Inputs
    By malcom2073 in forum Fusion Brain
    Last Post: 02-14-2009, 12:16 PM
  2. Replies: 41
    Last Post: 01-11-2009, 03:46 PM
  3. Fusion Brain and iBus
    By nemo1 in forum Fusion Brain
    Last Post: 12-15-2008, 11:05 AM
  4. Vista won't see the Fusion Brain
    By Ineffigy in forum Fusion Brain
    Last Post: 11-26-2008, 07:39 AM
  5. Fusion Brain and its uses!
    By HiJackZX1 in forum Fusion Brain
    Last Post: 06-08-2008, 07:41 PM
Tags for this Thread
