Results 1 to 3 of 3
Thread: problems with data logging
    Mar 2010
    I'm having problems getting the data logging feature working correctly. The only way I can get it to work at all is using the GUI timer. If use any other timers it doesn't record. Also I need to record at around 1 data point a second and no matter what I set the GUI timer to it records around 12 data points per second. Can anyone help me out?
    Mar 2010
    I figured it out. Everything works correctly in Windows 7 64 bit except the timers. I set it up again on a XP laptop and the timers worked correctly. It also worked in 32 bit Windows 7 using the logic timer.
    Mar 2006
    Colorado, but Canadian!
    Interesting... So the timers dont work in Win7 x64? I have not seen this before. I will log it as a bug and figure it out.
    Thanks!
    1.9in x 2.9in -- 47mm x 73mm
  1. How to use your VERIZON cell for FREE internet
    By racerboy6996 in forum Wireless Communications
    Last Post: 05-30-2010, 07:20 PM
  2. Replies: 42
    Last Post: 12-11-2009, 03:36 PM
  3. Digimoto 5.0 Beta Release
    By digimotojoel in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 02-26-2007, 12:34 AM
  4. Capture GPS data at the flip of a switch
    By Mr. Inquisitive in forum GPS
    Last Post: 02-02-2005, 07:06 PM
  5. VOICES Traffic Data
    By stevieg in forum V.O.I.C.E.S
    Last Post: 05-31-2004, 09:24 PM
