Results 1 to 7 of 7
Thread: 2nd brain
    Low Bitrate GadgetBandit's Avatar
    Oct 2008
    2nd brain
    I've added a second Brain, but configurator shows them to have the same serial number?
    Thanks,
    GadgetBandit
    Jan 2008
    i saw the thread title, and started imagining someone adding a second brain to themselves... but would that make you twice as smart, or twice as dumb?
    Oct 2008
    Hey, I bought my first Brain, so I could honestly say I had a brain, . . . without going into fractions.
    GadgetBandit
    Oct 2008
    Can I have multiple brains on one computer?
    Thanks,
    GadgetBandit
    Mar 2006
    Colorado, but Canadian!
    VID/PID will be the same.
    Hardware Instance ID will be different.
    MDX takes care of all of that for you. Just add the second brain and use like normal.
    1.9in x 2.9in -- 47mm x 73mm
    Oct 2008
    I got it. "Hardware Instance ID will be different." Hardware Instance ID MUST be different. By default Configurator will insert duplicate serial numbers for the ID. The user must hilight and enter a unique ID. Bingo!!
    The greenhouse has been under the brain's control for 2 years . . . now, it's time for the house.
    Thanks,
    GadgetBandit
    Mar 2006
    Actually MDX no longer uses the hardware instance ID as of early 2009 or so. It auto configs which is which. So as long as you are using the newest MDX, the hardware instance IDs shouldnt really matter.
  1. 2nd car battery
    By XMatrix in forum Power Supplies
    Last Post: 03-16-2010, 07:09 PM
  2. 2nd Battery
    By accord in forum Power Supplies
    Last Post: 09-29-2009, 03:14 PM
  3. Replies: 17
    Last Post: 01-16-2009, 10:48 AM
  4. Replies: 3
    Last Post: 09-23-2008, 10:00 PM
  5. How to add a Fusion Brain instance to your configuration file
    By 2k1Toaster in forum FB Documentation and Tutorials
    Last Post: 06-07-2008, 09:42 AM
