Results 1 to 6 of 6
Thread: Relay trigger
    Nov 2009
    Relay trigger
    I can i use the fusion brain to trigger and automotive relay? How would i code this using the software? For expample i want to push button to turn lights on.
    Mar 2006
    Colorado, but Canadian!
    Quote Originally Posted by themlruts View Post
    Yes, that's one of the main uses. We sell relays that plug directly into the digital output ports.
    Use the MDX configuration wizard, and you can setup a button to turn on and off an output in 30 seconds.
    1.9in x 2.9in -- 47mm x 73mm
    Nov 2009
    I am confused the nignga wizard? What about all the logic and stuff does it do that for you?
    Mo' Programming Mo' Problems
    Sonicxtacy02's Avatar
    Woodbridge, VA
    Blog Entries
    55
    What front end are you using? RideRunner and Centrafuse have plugins that will make it easy to control relays. RRFusion or Centrafusion
    Live mp3Car Facebook Chat
    Nov 2009
    Riderunner. I don't have to code anything
    Woodbridge, VA
    Blog Entries
    55
    Download. Unzip and out into the plugins folder. Open the folder and double click install.cmd. if the skin ur using has a rrfusion.skin your good to go. If not just copy the skin files from the plugin folder to your skin folder.
  1. FAQ: RELAYS; how they work and how to wire it up...
    By FusionFanatic in forum The FAQ Emporium
    Last Post: 06-16-2015, 06:58 AM
  2. Relays
    By FusionFanatic in forum VaultWiki
    Last Post: 09-24-2009, 08:19 AM
  3. StreetDeck Functions
    By god_of_cpu in forum DigitalMods (Scripts / API)
    Last Post: 01-15-2008, 11:44 PM
  4. AMP 1.X Phidget Plugin Interface
    By bcohen5055 in forum AMP
    Last Post: 09-06-2007, 01:10 AM
  5. Will someone help me program my relay control module
    By cproaudio in forum Software & Software Development
    Last Post: 09-04-2002, 05:50 AM
