So I wrote this config almost two years ago. I honestly barely even remember what most of it means. All I know is I finally after a lot of work got my steering wheel controls working.
The problem I've always had is my steering wheel buttons are toggles. For instance next track is a toggle up or toggle down. I often go to skip a track and I end up skipping 3-4.
I need to tweak the delays, but I can't remember what I should be changing. Hoping someone can save me spending all the time I did last time trying to come up to speed on MDX configs.
Config..
Code:
<?xml version="1.0" encoding="utf-8" ?>
<FusionControlCentreConfiguration version="3.0.0.0" author="Jayson" date_created="May 11, 2009 at 11:54:55 AM" last_modified="June 7, 2010 at 5:19:46 PM">
<require>
<!-- Begin Function Instances -->
<!-- End Function Instances -->
<!-- Begin Fusion Font Instances -->
<!-- End Fusion Font Instances -->
</require>
<speech enabled="false" global_politeness="true">
<!-- Begin System Speech Instances -->
<!-- End System Speech Instances -->
<!-- Begin System Speech Definition Instances -->
<system_definitions>
</system_definitions>
<!-- End System Speech Definition Instances -->
<!-- Begin Custom Speech Definition Instances -->
<custom_definitions>
</custom_definitions>
<!-- End Custom Speech Definition Instances -->
<!-- Begin Custom Query Instances -->
<custom_queries>
</custom_queries>
<!-- End Custom Query Instances -->
</speech>
<general>
<!-- Begin Remote Control Configuration -->
<remote status="disabled" user_name="default" port="4242"></remote>
<!-- End Remote Control Configuration -->
<!-- Begin COM -->
<com status="disabled">
<commands>
</commands>
<executable_commands>
</executable_commands>
</com>
<!-- End COM -->
</general>
<graphics>
<!-- Begin Global Graphic Settings -->
<main_display designed_for_size="5,5" show_at_size="5,5" menubar="Fixed" RunInSystemTray="True" MinimizeToSystemTray="True"></main_display>
<!-- End Global Graphic Settings -->
<!-- Begin Background Images -->
<!-- End Background Images -->
<!-- Begin Static Images -->
<!-- End Static Images -->
<!-- Begin Variable Location Images -->
<!-- End Variable Location Images -->
<!-- Begin Graph Instances -->
<!-- End Graph Instances -->
<!-- Begin Display Buttons -->
<!-- End Display Buttons -->
<!-- Begin Multi Images -->
<!-- End Multi Images -->
<!-- Begin Text Labels -->
<!-- End Text Labels -->
</graphics>
<io>
<!-- Begin Fusion Brain Instances -->
<brain id="MainBrain" version="3">{43b36ca4-5c35-485b-82f4-3957e44299b5}</brain>
<!-- End Fusion Brain Instances -->
<!-- Begin Timer Setup -->
<timer id="input" interval="50"></timer>
<timer id="output" interval="100"></timer>
<timer id="gui" interval="30"></timer>
<timer id="logic" interval="65"></timer>
<!-- End Timer Setup -->
<!-- Begin Digital Output Instances -->
<iochannel id="AmpRelay" port="0" brain="mainbrain" type="digital_output">
<defaults defaultstate="on"></defaults>
</iochannel>
<iochannel id="MonitorRelay" port="1" brain="mainbrain" type="digital_output">
<defaults defaultstate="off"></defaults>
</iochannel>
<!-- End Digital Output Instances -->
<!-- Begin Analogue Input Instances -->
<iochannel id="Steering0" port="0" brain="mainbrain" type="analogue_input">
<options history="0" auto_average="false"></options>
</iochannel>
<iochannel id="Steering1" port="1" brain="mainbrain" type="analogue_input">
</iochannel>
<!-- End Analogue Input Instances -->
</io>
<logic>
<!-- Begin Logging Setup -->
<all_logging>
</all_logging>
<!-- End Logging Setup -->
<!-- Begin Variable Declarations -->
<all_variables>
</all_variables>
<!-- End Variable Declarations -->
<!-- Begin Logic Declarations -->
<all_statements>
<if fire_on="logic" minimum_delta_vote_time="50" id="SeekUp">
<boolean_operation type="and">
<parameter1>
<boolean_operation type="greater than or equal to">
<parameter1>
<analogue id="Steering1" time="0"></analogue>
</parameter1>
<parameter2>
<number>0.8</number>
</parameter2>
</boolean_operation>
</parameter1>
<parameter2>
<boolean_operation type="less than or equal to">
<parameter1>
</parameter1>
<parameter2>
<number>0.9</number>
</parameter2>
</parameter2>
<then>
<do function="Send Key To Foreground" functionTargetID="Required Filler" vote_opinion="A" vote_priority="High"></do>
</then>
</if>
<if fire_on="logic" minimum_delta_vote_time="50" id="SeekDown">
<parameter1>
<parameter1>
<analogue id="Steering0" time="0"></analogue>
</parameter1>
<parameter2>
</parameter2>
</parameter1>
<parameter2>
<parameter1>
</parameter1>
<parameter2>
</parameter2>
</parameter2>
<then>
<do function="Send Key To Foreground" functionTargetID="Required Filler" vote_opinion="B" vote_priority="High"></do>
</then>
</if>
<if fire_on="logic" minimum_delta_vote_time="50" id="VolumeUp">
<parameter1>
<parameter1>
</parameter1>
<parameter2>
<number>2.1</number>
</parameter2>
</parameter1>
<parameter2>
<parameter1>
</parameter1>
<parameter2>
<number>2.3</number>
</parameter2>
</parameter2>
<then>
<do function="Send Key To Foreground" functionTargetID="Required Filler" vote_opinion="C" vote_priority="High"></do>
</then>
</if>
<if fire_on="logic" minimum_delta_vote_time="50" id="VolumeDown">
<parameter1>
<parameter1>
</parameter1>
<parameter2>
</parameter2>
</parameter1>
<parameter2>
<parameter1>
</parameter1>
<parameter2>
</parameter2>
</parameter2>
<then>
<do function="Send Key To Foreground" functionTargetID="Required Filler" vote_opinion="D" vote_priority="High"></do>
</then>
</if>
</all_statements>
<!-- End Logic Declarations -->
</logic>
</FusionControlCentreConfiguration>
