Results 1 to 6 of 6
Thread: Has anyone tried the FB with a wireless USB hub?
    Aug 2006
    Central PA
    If so, what was your experience like?
    Mar 2006
    Colorado, but Canadian!
    I have not but that is definitely an interesting idea. I don't know why it wouldn't work, they are made to support all modes.
    1.9in x 2.9in -- 47mm x 73mm
    Aug 2006
    Central PA
    The reviews I found aren't so great. Most people said around 7 - 10 ft of clear line of sight the signal starts to fade/get weak/drop. Also, simply putting your hand in front of it would interrupt the signal.
    Mar 2006
    Well that sounds like a really poor design then... Almost sounds like wireless keyboard/mice in the IR days.
    Aug 2006
    Central PA
    I actually just ran into this bad boy. A cat5/6 cable would make this simple, but one could also hook up a cheap wireless router that supports client bridge and you'd have a nice reliable wireless FB. A directional antenna could be added for FB goodness that could reach for miles with clear line of sight.
    This one may work too, but it doesn't say if it supports tcp/ip or if it has it's own custom way of transmitting the data. It's cheaper and would work with a cat5/6 cable though.
    Low Bitrate GadgetBandit's Avatar
    Oct 2008
    Has anyone tried eithe of the 2 devices scotty pointed out?
    GadgetBandit
  1. Replies: 17
    Last Post: 01-18-2011, 06:42 AM
  2. wireless card or wireless car and access point?
    By vanroth in forum Wireless Communications
    Last Post: 06-08-2004, 11:46 AM
  3. Replies: 1
    Last Post: 04-15-2004, 04:20 PM
  4. Wireless lilliput 7 touchscreen wireless.?
    By Nokia6600 in forum LCD/Display
    Last Post: 02-29-2004, 08:45 AM
