Results 1 to 6 of 6
Thread: Simulate push button and enable/disable button
    Variable Bitrate rEegLer's Avatar
    Jul 2008
    Mechanicsburg, PA
    I searched but I feel like the search function got worse with the forum upgrade.
    Two parts:
    Part 1: All I'm trying to do is simulate a push button. I would like to see the button be pushed but when my finger or point releases the button, the button goes back. I feel like it should be very simple but it's frustrating the crap of me right now.
    Part 2: I would like to have two buttons to control an relay. One button enables/disables the other button that actually triggers the output. When I set it up the way I think it should be, the button says it's disabled but if I click it, it triggers the output anyways.
    Any help would be greatly appreciated.
    rEegLer
    Love
    Nov 2009
    you mean a momentary push button?
    Jul 2008
    Mechanicsburg, PA
    Yes. I know it's simple but it's the combination of everything that is confusing me.
    Love
    Mar 2006
    Colorado, but Canadian!
    When you make a button, there is an option to make it momentary and it does exactly what you describe.
    1.9in x 2.9in -- 47mm x 73mm
    Jul 2008
    Mechanicsburg, PA
    Ah yes you're right. I've stopped using the configurator as it erases my PWM settings when I opened my config file. So instead of "Attached" it should be "momentary" in the config file?
    Love
    Mar 2006
    yes PWM is not in the current configurator. But you can open it, add your button, then copy/paste the raw XML output into your file and not save with the program. Best of both worlds.
  1. voice command without having to push button
    By AltimateX in forum Centrafuse
    Last Post: 02-11-2009, 08:14 AM
  2. Push button wiring question
    By Malvagio1987 in forum LCD/Display
    Last Post: 01-28-2008, 05:04 PM
  3. Low Profile Push Button Switch
    By anonim in forum General Hardware Discussion
    Last Post: 08-03-2007, 05:47 PM
  4. why do i have to push the power button after shutdown?
    By kalito in forum General Hardware Discussion
    Last Post: 03-15-2005, 09:00 PM
  5. Simulate holding down mouse button for Lilliput
    By badandy4you in forum LCD/Display
    Last Post: 05-21-2004, 07:20 PM
